Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: My 1984 Yamaha 200e "Yamahauler" Restoration
    Yukon Canada
    59
    Ha ha I hard a hard time not spewing my mouthful of beer. Someone should post a pic of that. I havent figured out how to post pic from my ipad. Its driving me crazy.
    Mar 2012
    Ontario, Canada
    20
    Quote Originally Posted by trimoto200e View Post
    Sorry if it's blurry, but you can read a bit of the text. There you can see the HARF and hour text.
Name:	Yamaha 200e Three Wheeler Progress 012.jpg
    My Trike(s):
    1984 Yamaha 200e "Yamahauler" - Got it totally for free, but needs major repair.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Griff747 View Post
    I happen to have the Factory Service Manual. Helps a LOT!
    Now, another topic to throw out: Which side of the engine would be easier to get into the tranny? Like I said before, we're missing the 1st gear inside, but luckily the fella who previously owned this bought the gear in 2002.
    You have pull the motor and do a complete tear down and split the cases to get to the tranny. It's a lot of work and while you have it apart you can freshen up the motor ( rings, bearings if they are bad, valves, clutches, ect ).
    Howdy
    Mar 2012
    Ontario, Canada
    20
    Good news everyone! We have moved the Yamahauler to a new location, and we made some great progress with it. We were able to start it up, and lemme tell you, IT SCREAMED LIKE A LOUD CHAINSAW that it scared to hibbi mijibi's out of me! We know are making some great progress. I'll hope to post some more pictures sooner or later this coming Wednesday/Thursday. Have a good weekend!
    My Trike(s):
    Maine
    463
    Good luck with the resto. I just picked up 2 1983 ytm 200's for 50$. After cleaning the carb, gas tank, new plug, new lines, changed the oil, clean mouse nest out air box, etc it started right up and drove it around to check the gears..Now I'm also in the process of restoring mine..I got mine stripped down to the frame. A little tip is I use zip lock baggies and mark the contents witha marker to keep track..A month or 2 down the road and I forget where all these bolts and screws go...lol
    Mar 2012
    Ontario, Canada
    20
    Well, good news again is that when we fired the Yamahauler up again, I lightened the throttle down and it sounds like a purring kitten! Now, we hope to test ride it soon, but the only major problem is that sometimes it only idles for a minute and then just shuts off. Anyone know how to stop the problem?
    My Trike(s):
    tripowersport's Avatar
    tripowersport is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2012
    pa
    292
    Try to clean the carb, jets really good and put in a fuel filter. I put on a fuel filter, cleaned my carb over and over then it was good. good luck.
    Jan 2013
    Iowa
    18
    i just bought one of these bad boys in perfect condition (other than teh fact that when you shift into gear it doesn't move...)
    glendive, montana
    1,822
    jdt are you shifting down or pulling the lever up? the yamaha's go up into gear, unlike earlier hondas where you push down.
    Mar 2015
    Denver
    27
    Anyone still following this thread? I could use help
    Apr 2014
    Edmond, KS
    2,591
    You could always start your own thread.
