Results 1 to 2 of 2
Thread: yamaha dt 250 ALMOST GOT HER RUNNING!!!!
    Jan 2011
    Avon, Minnesota
    641
    so tinkering on this old bike i have been having a hard time with. so i took off exhaust pipe/cables/carb/reeds and checked everything out. bought some new points and condensor and a throttle cable. put the points and stuff in and it has spark!!! nice blue spark. this is with only 1 wire from the stator going to the coil. so i ordered up a wire harrness i finnaly found of ebay and recieved it yesterday plan on putting that on this weekend. but i found out when i was cleaning the carb im missin the choke plunger. and also there is a crack in the bowl behind the float. so i plan on fixing that with some jb weld puddy stuff. Also noticed when i turn the twist throttle its easy to turn but does'nt go back to standard position. where ever you leave the throttle is where it stays. what would make it do that?
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    Six Stroke's Avatar
    Six Stroke is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central Minnesota
    315
    Try lubing your throttle cable; if that doesn't work, get a new one. Oh yeah, make sure the throttle tube turns easily on the handlebar. Graphite lube wouldn't hurt.
    1985 Yamaha YTM225DX
    2014 Yamaha WR450F
    2008 Yamaha TW200
    1975 Honda CB400F
