Results 1 to 14 of 14
Thread: need to come up with a new tri z gas tank
    jmax857's Avatar
    jmax857 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    bancroft canada
    354
    So on my tri z my gas tank is leaking. I took it off to pplastic weld it, but the pplastic is so old and brittle I don't think I got a good seal. There's not many z parts around here so I need some sort of a tank. I want to make a custom one, I was going to try and make one from a heinekin mini keg, but its obvious that the metal is much too thin to use. A friend suggested finding a fire extinguisher the right size, or welding 2 small ones side by side. But I'm not the hugest fan of that idea. Has anyone made their own custom under the seat tank for their z?? Or anyone got any good or crazy ideas? Preferably made from steel so I can weld mounting brackets and what not. If I can't come up with something I have to take the time to make one from scratch, which I don't really have the time to do.
    florida
    186
    i would make it out of aluminum, not steel. if you need one fabed up i could help you out.
    jmax857's Avatar
    bancroft canada
    354
    Aaluminum would be much nicer. Just wwith steel, I can do all of the work myself with minimal costs.
    florida
    186
    i agree with you there. i try to do most or all the work on my trikes too. but if you change your mind give me some measurements and a pic and i can shoot you a price.
    Southern MN
    1,875
    Why not make a top mount tank? There are a few guys that run them on here, they are made of aluminum and replaces the stock airbox up top, and eliminates the pos fuel pump and vacuum lines. This stock setup was a big downfall for the Z if you ask me.
    The other idea is to get a stock one off ebay. The Z tank seems a dime a dozen, from what I have seen in the past a guy could have picked one up for about 40 dollars. Surely one of the sellers would ship to Canada..
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    zzmegad's Avatar
    zzmegad is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2008
    North of Chicago
    317
    I kinda like the under seat tank, it helps give the Z it's look. Yeah its an extra system to maintain but mines been going about 5 years now without a problem. I agree tho it does suck at times.
    jmax857's Avatar
    bancroft canada
    354
    If I take the time to fab one from scratch, it would be a top mount tank. I was hoping to find something I could just weld some hose barbs on, couple vents, and mount it. Something cool that would turn heads.also a lot of the top mount tanks only hold about 3 litres if I can remember, I won't settle for any less than 5 litres.,
    Rittman, Ohio
    6,276
    Call me crazy, but if you want an under the seat gas tank for your TriZ, why not use another TriZ gas tank? They are cheap and plentiful. I think I might even have a couple.
    na
    5,702
    There was a time you couldnt give stock Z tanks away. Ebay 12.99 with no bids.
    Proudly NOT a member of
    "Team on the Teat"
    jmax857's Avatar
    bancroft canada
    354
    I think everyone is missing the point here. Yes I am smart enough to figure out on my own that yoou caan replace a broken tri z tank, with yes, another tri z gas tank.
    But I kind of want something a little more custom, cool, and different.
    House Springs MO
    5,496
    Quote Originally Posted by jmax857 View Post
    Then get to work Professor.
    jmax857's Avatar
    bancroft canada
    354
    No need to be a hater.
    Anyways, the other reason I don't want to use a stock tank is because I have a trx450 rear shock, and the resevoir touches. So I had to heat, and reshape the stock tank a little. Which is all fine and dandy but I broke the fuel fitting off and had to plastic weld a new one on which is where its leaking, if I take the time to re shape a stock tank again, it would work fine but I would rather put my time into making something different. Has no one made a under tthe seat gas tank themselves?
    House Springs MO
    5,496
    No "Hatin" here. You asked a question, others gave you suggestions, and you didn't care for said suggestions. Well then the only other possible outcome is to get out in the garage and make something happen. The computer isn't going to build one, so get to work.
    jmax857's Avatar
    bancroft canada
    354
    Its -10 and snowing. Sposed to warm up this week, then I will go outside and staart mocking stuff up.
