Results 1 to 15 of 19
Thread: Copper head gaskets?
    Apr 2006
    Crestview, Florida
    2,429
    Where can i get a copper head gasket, or something that wont blow out so easy for a 85 200x?
    Rides
    85 ATC350X
    85 ATC200X
    200xman123 is offline Quote: "sorry im not the sharpest tool in the shed" Arm chair racerFirst time rider
    hartford vt
    171
    http://www.ebay.com/itm/320860888946...84.m1497.l2649 this is what i bought because when i bought my 200x it already had a copper one on it that was leaky so i bought this one its great
    Aug 2010
    Southern Oregon Coast
    932
    you can still get the OEM head gasket, last time I checked. Make sure your head isn't warped, also
    Dec 2005
    Wisconsin
    1,141
    If you want to get rid of that copper head gasket...send it my way. Fyi you need to anneal the copper before you reinstall them.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    6,779
    The copper BAPP 200x head gaskets will seap oil , just the nature of the gasket . I have never seen one blown out before ? Your head prob needs to be resurfaced !!! If your using a 12:1 piston you need the copper gasket IMO .
    Quote Originally Posted by 200xman123 View Post
    Apr 2006
    Crestview, Florida
    2,429
    I have a 12:1 and have been running the cheap-o ebay gaskets. Thats why i want a copper, just not sure where to get one.
    Rides
    85 ATC350X
    85 ATC200X
    torque's Avatar
    torque is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2011
    saskatoon sk canada
    308
    a bapps copper head gasket will take your 12:1 closer to 12.5:1 i looked for months and finally found one from a member here.
    Apr 2006
    Crestview, Florida
    2,429
    no ideas where to find one?
    Rides
    85 ATC350X
    85 ATC200X
    6,779
    Their not an easy find and havnt been made in prob 25+ years . Keep posting a wanted ad and you might get lucky like Torque did
    Quote Originally Posted by Erics350x View Post
    Scootertrash's Avatar
    In the sticks
    4,638
    What was the thickness on the old BAPPs copper gaskets?
    torque's Avatar
    Aug 2011
    saskatoon sk canada
    308
    i just measured mine and compared it to to a stock gasket. the bapps gasket is about .42 mm thinner than the stocker
    In the sticks
    4,638
    Quote Originally Posted by torque View Post
    What is the actual thickness of the copper gasket? I don't have a stock gasket here for comparison so the actual number for the copper one would be best. Thanks torque!
    ETA: What is the stock gasket made from?
    torque's Avatar
    Aug 2011
    saskatoon sk canada
    308
    the bapps gasket is 1.02 mm. i just checked my facts the compressed thickness of a stock gasket is 1.32 mm.
    while were on the subject what makes the the bapps copper gasket so good, other than the raised compression.
    the copper aids in cooling the combustion chamber and the thinner gasket reduces the quench distance witch builds detonation resistance into the engine.
    Apr 2006
    Crestview, Florida
    2,429
    They cany be thats hard to make. Why cant someone on here cut a few outta copper and sell them? Maybe a couple 350x ones also. I guess till then ill just use another cheap-o.
    Rides
    85 ATC350X
    85 ATC200X
    In the sticks
    4,638
    That's what I have running thru my head. Maybe I'll pick up a sheet of copper and try to make one. All I've got is 200S head gaskets right now, but they would work for practice.
    ETA: Maybe I just found out why no one makes these any more. A 12X12 piece of ASTM B370 110 copper sheet would cost me 39.59
    I figured 6X6 for one gasket so I would get 2 gaskets out of a 12X12 so 20.00 per gasket in materials
    Soooooo would people be willing to pay 40-50.00 for a copper gasket? (20.00 for materials, 20.00-30.00 for labor)
    Eric-get your head checked to make sure it's not warped too.
