Got my '84 200x running 8) . It was fun when it came to life and whole mouse nest went flying out the tailpipe. That problem is out of the way, but it still needs a clutch replacement. My question is... what are the honda part numbers for the special sockets to get the nuts off in there. Also, what should I buy to put in there. Do I only need the plates and friction material, or should get the springs, center, and pressure plate as well. This thing won't even move a little in gear and you can wiggle the basket by hand and also turn the center around with out much reistance.
