I just rebuilt my 85 200x, its bored .50 over with the matching piston for the bore, all new gaskets, I had a valve job done (with new valves installed) the rings are installed correctly, valves are adjusted, timing correct, everything checks out, accept I think i'm running a tiny bit lean. It starts first kick runs amazing in every way, it seems very powerful and everything(accept I haven't really opened it up at all)I did a cold compression test and its 120 psi and then I did a warm compression test and its still 120 psi I didn't do anything performance to the motor so I don't know if this is a fine reading and I didn't do a test before I started running it so I don't know if its gone up at all. I have only been running it(slow break in) for probably an hour and twenty minutes total. So my question is, does this reading sound normal?
