I am in the market for a ramp to load trikes into a pickup bed ? help is not always around so what do you guys use ?
thanks !!!
thanks !!!
84 200s almost done
84 atc 70 project
i picked up a set from tractor supply a few years back they are a tri fold ramp and they are aluminum and light, they have lasted years now and strongly reccomend them. but i will say if you drive a lifted truck, mines a 03 f 250 6 inch lift on 35 inch tires. you will want somethign a little longer.
I have a 2002 tacoma 4x4. Its not lifted .
84 200s almost done
84 atc 70 project
I think I got my trifold aluminum ramp at harbor freight. You can't hardly beat it.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
I just pick the front wheel up and set it on the tailgate. Then I get ahold of the grab bar and lift, push, grunt, and cuss when the front wheel turns and I have to start over. I need to get a set too, but I cant bring myself to spend the money on a set. LOL
Current rides
Taurus 650 (green)
85 250es big red
82 ALT50
82 ALT50
71 QA50
93 TRX 300 FW
Back your truck up to a hill with the tailgate down and ride the trike right on, other then that you can just get 3 boards and hope none of them slip while pushing it on.
My opinion on a loading ramp: the great day inc. tri fold ramp. aluminum very light weight. sturdy, will actually load a utv.
i picked up some loading ramp ends that bolt to 2x6's and use those .work pretty good .i even drive my brute force 4x4 up them with no problem .probly get them at lowes , home depot , or maybe tractor supply .
Here's what I use. Long enough for a 4wd GMC. $142.99 delivered to my front door in the big brown truck. Rungs are 5 1/2 inches apart.
http://www.discountramps.com/wide-atv-ramp.htm
Just make sure they don't slip off the truck.
I load mine straight across from the lawn to the driveway.
Just enough hill to be even with the tailgate and the dunes has a loading dock type ramp to offload.
Whatever you get, make sure you lock it to the truck when yer off riding so they're still there when you get back.
just hook bungee cords from the ramp to you hitch or bumper so it keeps it up against the truck . or a strap .
