Results 1 to 15 of 17
Thread: 1986 Honda TR200 FatCat project
    Nov 2011
    British Columbia
    15
    Hey folks,
    Though I'd post a few pictures of my modified '86 Fat Cat which now has the front triple-clamps off a '86 Honda 350x and the forks off an '82 XR200. I reused the stock FatCat hub and axle, although I also mounted the front aluminum wheel off an '86 250X. As well, I had to fabricate a 7/8" spacer to extend the rear shock (just height, not travel) as the front forks add about 4" of travel vs. the stock FatCat's.Click image for larger version.
ID:	141731Click image for larger version.
    The pictures a little old, but now I also fitted the front brake plate/cable from an '82 XR200 as well due to length issues with the standard TR200 cable setup.
    All in all, very happy with the results now, the bike soaks up the bumps better and the stance is nicer having the extra height.
    Coming soon: Front 200x disc conversion and aluminum silencer mounted.
    Cheers,
    Dave
    Nov 2011
    British Columbia
    15
    Couple more pictures:
    Bike when I first got it stock.Attachment 141736
    Added bark busters, new grips, and fabbed a lengthened stainless kickstand to compensate for the extra height.Attachment 141737
    Fitting the stock light shroud to the new 350x triples to check the fit.Click image for larger version.
    It worked out the the stock Fatcat fender and light braket bolted right up to the 350x lower triple crown, whereas I believe the 200x models mount a little different.
    Nov 2011
    British Columbia
    15
    Also just finished these off last night, I welded some extra steel around my footpegs to make them wider. Obviously nobody makes aftermarket ones for these bikes and no other parts interchanged from Honda.Click image for larger version.
ID:	141753Click image for larger version.
ID:	141754Click image for larger version.
    ontario
    1,131
    looks great. I have always wanted a fatcat.
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    connecticut
    59
    Nice FATCAT, cool mods! Don't see them often with mods..too rare I guess?
    Jul 2013
    Nice work I'm in the process of making my Fat cat into a Dual sport bike and at a slower pace , but need to do something this the suspension , especially the rear , it blows have you done anything to
    the rear suspension?
    Jun 2013
    Georgia
    53
    Those must be hard to come by. Haven't seen one in person and only a few online. Would love to get my hands on one.
    Jul 2013
    Quote Originally Posted by Amazon3d View Post
    well Just for Info's sake. 1987 ATC 200x , front suspension Disc brake and complete manual clutch Engine will bolt right up will minimal effort only the intake manifold and upper motor mount off the fat cat have to be installed on the 200X engine
    and with the clutch also comes the 6 speed transmission too!!! you will lose the E start and battery with the 200x wiring
    May 2013
    I have an 87 Bw200 and an 85 tr200 fat cat, now you've got me wanting to do some mods lol.
    Nov 2008
    Marblehead
    18
    That is really cool! I can't remember the last time I saw one!
    Nov 2019
    Maine
    Quote Originally Posted by redsled View Post
    Hey folks,
    Cheers,
    Dave
    Dave
    I'm new to the forem but have a stock 86 fat cat that I'm looking to do some improvements on. So I need a 86 350X front forks? what type of rear shock did you buy? As you can tell I'm a newbie to all this stuff so any help would be appreciated. Great job on your conversion!
    Jul 2018
    TN
    1,065
    Nice! Very nice. That's really cool. Always loved those. Never could find one around here when I actually have money.
    Nov 2019
    Maine
    Hi Dave
    Great post! I', a new owner of an 87 Fat cat and love the upgrades you did. Just so I'm clear, I need to front triple-clamps off a '86 Honda 350x and the forks off an '82 XR200 to make the change to mine. Did you buy a new rear shock or did you just re-use the old? If you were to buy a new one, can you reccomend a manufacturer and size? thanks again. Hogie
    Apr 2007
    zanesville
    22
    man would love to see more pics and details on this im working on one myself i used a xr200 al baker head pipe and fabbed the rest to a alum silencer i had web cams send me a cam and running 2nd over bore 11.1 piston it runs good just need to work on my suspension had thought about 350x front end with disc but liking what you did
    Jan 2020
    Richmond Texas
    Do you have pictures of your spacer?
