Results 1 to 11 of 11
Thread: Pilot jet cleaning in the carb. Best way and how often to do it?
    detroit michigan
    80
    My own recommendation is let the jets sit in carb cleaner over night , ( the carb cleaner will be gone/evaporated by morning so dont panic lol) that should loosin the gunk enough to pick the muck out of the jet with a sewing needle (be gentle though) ,when all muck is removed you should be able to blow through it without any stop ups. Dirty jets are a nuisance thatll get on just about any riders nerves on any old machine after its been sitting for any prolonged amount of time. I start my 185s every 2/3 weeks just to prevent it , it always starts first pull and runs smooth forever. Heres a 82 185s needle after sittin with just oil in it for 2 years It was a fun rebuild. Lets hear your advice and tips on this matter.
    burnin rubber
    Jun 2009
    Leander TX
    2,217
    Drain the carb after every ride. Problem solved.
    If any jet looks like that, it's getting a $20 carb kit.
    I've been known to pull a strand of copper wire out of a speaker or power wire and use it to clean jets in the past when they're really plugged.
    Feb 2012
    Gulfcoast
    26
    I have an old pot that I boil any carb that I rebuild in. I'll boil the carb for about an hour in water and alittle bit of simple green. When you pull it out it almost looks brand new. Then I'll take my blow tip on my compressor and blow everything out. Before you boil it take it completly apart so it gets everywhere and you don't melt anything, like the float.
    detroit michigan
    80
    Ah yeah the throw em away cause there dirty thing.
    After cleaning that it looked brand new, and worked like new , never give up never surrender . And never throw away mullah on parts that are easily refurbishable. Then again if ya have it spend it too. XD
    burnin rubber
    Dec 2011
    Ontario, Canada
    509
    Is the smaller jet supposed to be able to blow right through mine doesn't seem to be the pilot jet does though but it is alot bigger of course and easier to clean
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    2002 blaster sorry lol
    detroit michigan
    80
    Cool the smaller jet.
    lol the small one may give ya a headache, use a compressor. XD
    burnin rubber
    Oct 2007
    Minneapolis mn
    4,067
    Heat them with a small butane torch... Pops the crap right out...
    detroit michigan
    80
    OMG thats a great idea just make sure to hold the needle tight so it dont slip outta yer fingers.
    burnin rubber
    Jul 2011
    Eau Claire, WI
    1,188
    I like this stuff.
    Feb 2012
    Alabama
    6
    can anybody tell me what my 3wheeler is the vin is 4u3-2007255. thank y'all
    STL
    3,560
    Butane torch is a great idea! why didnt I think of that?!
    my solution to carb issues with current set up: buy a new carb HAHAHAH im being lazy and was upgrading anyways.
