Results 1 to 10 of 10
Thread: difference between 85 and 86 big red?
    ATCcountryboy is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2011
    South-bama
    240
    Is there a difference between a 85 and 86 big red 250? Are the engins the same?
    1. 1986 bigred 250(the huntin' rig)
    2. 1985 bigred 250(the workhorse)
    4 wheels? Sounds to safe.
    Beaver Falls, PA
    2,666
    The engine is the same. What's different are the swing arm/rear brake system, the '86-'87 had a cold start system in the carb, the seat color('85-black,'86-gray,'87-charcoal)and the decals are different. I may have left something out, or was wrong about something, so if so, someone more knowledgeable can correct me
    NEPA
    7,051
    All correct above,,the starters and reduction gears are different. But as far as dropping in a Complete engine. Same.
    Lewiston, N.Y.
    1,477
    The 86 and 87 had better water proofed rear ends.
    Tionesta, PA
    5,747
    the 86 model had a larger head pipe heat shield, and also a helmet holder and a lockable front steering, like street bikes have.
    tapage is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2012
    Montrose, IA U.S.A.
    166
    is there any difference in the axels or there housings?
    Sarnia, Ontario, Canada
    3,415
    Quote Originally Posted by tapage View Post
    both axle and the rear tube/swing arm are different..
    pretty sure you could swap the entire rear swing arm with all that it includes but definitely not the individual pieces
    (axle, hubs, rear brake assy...) only the differential is a direct bolt on that will cross the 85-86 gap..
    I just put an 86 diff on my 85..tell the people ACE!!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Pacific NW
    4,255
    Timing chain tensioners may be different.
    Apr 2015
    central newfoundland canada
    Will the left side hub from an 85 fit an 86? I know the right hub won't fit due to the brake.
    85 250 ES
    86 250 ES (X2)
    87 250 ES
    NEPA
    7,051
    No, different. An 86 needs a 86 or 87 hub.
