Thread: 200x rear brake layout?
    bucko is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2011
    Marion,Ohio
    255
    Im having trouble figuring out how the brake caliper and mount for it hook up to the rear end on my 86' X?I look at the diagram but it really doesn't show how or where I mount it.Could someone post a picture of their close up so I can figure this out please.
    You have the large brake stay plate, with the huge circlip.
    Then the caliper has a mounting bracket with 2 slide pins. If you have the correct stuff, there's nothing to explain.
    Download a free manual, that may show you some more.
    Many calipers will fit, you just may have to make a bracket. When I got my 86, it had a single forward slide pin and a rear pin mounted to a 3/4 x 3/4 piece of angle iron......
    Jan 2011
    Marion,Ohio
    255
    thanks!Guess I must not have all the stuff cause there is no slide pins.
    ^ Or you have no pins sliding because they are seized. There are 2 brackets to mount that, one is the caliper bracket with 2 slide pins (one an allen head under a dust boot, one a 12mm hex next to the bracket, one is the brake stay bracket with the large clip.
    Any parts fiche will show you all the parts.......
    http://www.servicehondapsn.com/fiche...1986&fveh=2807
    15 and 16 are the slide pins, 5 is the bracket.
