Results 1 to 9 of 9
Thread: Shift shaft seal
    DSHOT59's Avatar
    DSHOT59 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    sayreville nj
    155
    Shift shaft seal
    Anybody know if the seal on the shifter shaft can be changed with the shaft still in ? In other words from the outside can it just be pulled out and changed. It`s a 83 honda 200 and i`m tired of that drip hope`n it`s an easy fix. Thanks for any and all info.
    KgoX is offline New to the board Arm chair racerNew to the board
    Oct 2011
    CA, usa
    54
    I have changed my SL100 and my CB750F shift shaft seal from the outside so hopefully your 200 follows suit.
    Camano Island, WA
    361
    Since youre replacing the old seal, you can beat the heck out of the old seal, and destroy it getting it out. then carefully slide the new one in.
    Sarnia, Ontario, Canada
    3,415
    An old school way of removing a seal with the shaft still in is to carefully drill a small hole on either side of the shift into the metal shell of the seal. Then take a small screw and thread into the hole you just drilled, after that using a small claw 'pull' the screw like it were a nail in a board. If your pressure is right and you have a gentle hand the seal will pop out..
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    I always tear off the corner of a ziplock bag, place it on the shift shaft and grease the inner lip when re-installing the new seal this way.
    The splines can chew up your new seal.....
    Many leak because the shaft is bent, so if it doesn't hold up, be ready for that.
    Dec 2005
    Wisconsin
    1,141
    Do what dougspcs said for removal, and use DC's advice for installation. Before you install the seal pack the back of it with wheel bearing grease, this will keep the spring from jumping out when you tap it back in with a socket. Enjoy and have fun!
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    DSHOT59's Avatar
    Mar 2009
    sayreville nj
    155
    Thanks guys good advice like the plastic bag trick and the pack it with grease thing. Thanks to all for the replies. Wasn`t real worried bout gettin it out figured I could just mangle it and it wouldn`t matter anyway just didn`t know if it would go in right with the shaft still in. It only leaks after a ride when it`s hot don`t know if that means anyting or not figured the rubber was just done from being old now i`m hope`n it`s not a bent shaft guess we`ll see thanks again guys.
    Pacific NW
    4,255
    Not sure if it matters, but we used to use contact cement to
    glue in rear main engine seals.
    They were pretty large so they had a tendency to creep back out.
    Like like the way 1/2" pvc pipe will stay put but the larger sizes need to be held in place until they set.
    I've also never heard of anyone gluing a shift shaft seal.
    I didn't glue mine either and it stayed put.
    The only thing was feeling silly for waiting so long to spend 4 dollars
    and take the 10 minutes to do it.
    Oct 2011
    CA, usa
    54
    Quote Originally Posted by tri again View Post
    I've been there more then once...I'm trying not to do that sort of thing anymore.
