Results 1 to 15 of 17
Thread: flush / clean out gas tank
    Nov 2011
    NH
    40
    Any tips? I removed the tank and tried flushing it out several times but i can still hear/see dirt inside.
    Oct 2011
    traverse city, mi
    15
    I have gotten rid of rust in tanks before by filling them with white vineger and letting them set a few days, giving them an acasional shake every day or so. Once its rust free, I run a garden hose in it for 5 mins to flush any particles out. try to get as mutch water as i can out, then shake some gas/2 stroke oil mix in it, dump that out and fog the tank with wd40(dont be stingy.....Doing this should leave you with a new looking tank. Good luck!
    Aug 2010
    Southern Oregon Coast
    932
    Quote Originally Posted by sleepyweasel13 View Post
    x2. works good
    http://www.mopedarmy.com/wiki/Removi...rom_a_gas_tank
    Nov 2011
    NH
    40
    thanks I will try that but what is "x2"
    Oct 2011
    L.I. / Gilboa NY
    104
    he agrees...times 2
    riding my cousin's '83 250R & '84 200X...R.I.P.
    Just bought an '84 YTM 125
    my '84 200S
    my nephews '85 Tri Zinger 60
    my wifes '83 ATC 110
    owned an '85 & '86 200X
    always looking for a 350X!
    Take a second and look at the tag...Is it Made in America? Do your best to make sure it is before you buy it.
    Nov 2011
    Morristown, NJ
    137
    X 2
    I'll be doing this in a couple weeks along with repainting the tank
    Pacific NW
    4,255
    My latest LAZY way is to use soap and boiling water.
    Pressure wash the inside like at the car wash, or garden hose will do ok too.
    dry them totally, maybe even a rinse with that
    fuel line dryer called 'heet' to remover ALL traces of moisture.
    Blow out with compressed air for 10 minutes and then either fill and KEEP full with gas
    or spray the inside with fogging oil, used to winterize marine engines.
    Of course, there are 100 other ways too, but I figure if they're clean and not throwing any More rust,
    and you can stop them from rusting any more, we're 99% where we need to be.
    IF I get serious, it would be radiator shop clean out or muriatic acid wash at home and
    coat with por15, but again,
    if they're clean of chunks and dust and not plugging the carb,
    keeping them full full so there no room for oxygen or condensation to promote more rust
    or
    dead empty and drydrydry moisture wise and hanging inside with low temperature fluctuations and
    the cap OFF!
    My last sx was factory new. Guy drained the tank, and parked it in a heated garage but the gas cap was left on.
    it accumulated enough moisture in the tank from breathing that you can easily jam 4 fingers thru the bottom of that tank.
    And it looks NEW new new on the outside. so very sad.
    If you can get the search key to work for you, there's enough info on this topic
    to make your head spin
    Cold Lake, Alberta, Canada
    3,013
    All good advice.^ If you have some stubborn rust/dirt inside, put a handful of screws or gravel in it with vinegar/soap & water or whatever you want to use and shake it around. That will 'sand' the inside clean. POR 15 makes a great product for cleaning the inside of tanks. I think it's called "Marine Clean".
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Nov 2011
    NH
    40
    thanks for all the advise. I got it nice and clean and put back together. But I must have done somthing wrong putting the carb back together because when i turn the fuel on it runs out the drain (yes I did close it ) and the over flow vent tube. Maybe I should start new thread for that question?
    3,013
    Your float is stuck partially open. An common result of cleaning carbs sometimes. You loosen crud up that wasn't an issue before. If a light tap on the side of the bowl with a screwdriver handle doesn't stop the flow, you'll have to tear it apart again to clean the needle and seat. Also make sure your float is adjusted to the right height.
    Edit: Forgot one easy thing to try. Shut off the petcock, start the machine and let it run until it dies. This will allow your float to drop and maybe flush out the dirt.
    Last edited by coolpool; 11-16-2011 at 07:26 AM. Reason: I forgot the easiest trick going...duh!
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Pacific NW
    4,255
    I've gotten lucky sometimes by taking off the fuel line from the tank or just using a foot or so of new clear line,
    , open the float bowl drain and then blow into the fuel line, maybe even a few drops of 2 stroke oil or mystery oil.
    It blows past the float valve and just MAY work.
    Mouth pressure is enough.
    Otherwise, what coolpool says.
    Apart again and maybe a Q tip in the float valve seat.
    If it's real cruddy, toothpaste can help since it's a mild abrasive.
    and check the rubber tip on the float needle..AND the little tiny spring plunger on the opposite side of the rubber float needle tip.
    It touches the float itself, spring loaded and sometimes gets stuck.
    It's so small it's amazing that it even works at all.
    Plattsburgh, NY
    2,311
    KBS also makes a rust remover and tank flushing stuff and a sealer like red coat.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Nov 2011
    NH
    40
    thanks guys this is all very helpfull info. Im really not dumb (I dont think) Im just new to this. thanks again. Im sure Ill have more questions.
    Nov 2011
    NH
    40
    OK I have tried all the tricks and none worked so I have removed the carb again. This time I noticed there was a small break in a peice that attaches the float to the bracket that holds the pin. Could this be the Problem? If so where could I get one? My local dealer said they could order one. Maybe I could order ne online.
    Dec 2010
    S.E. Illinois
    1,178
    Quote Originally Posted by drjoe171 View Post
    Pressure wash the inside like at the car wash, or garden hose will do ok too. dry them totally, maybe even a rinse with that
    why spend that much on Heet? just use rubbing alcohol, that's basicly what Heet is.
    74 HONDA ATC 70
