Results 1 to 15 of 15
Thread: 200x speedometer setup help
    Lewiston, N.Y.
    1,477
    Got the speedometer all set and functional. However i was wondring if there is anything to hold the gearbox unit in a stationary position? It moves forward or backward depending on my direction of travel....is this normal? Here is a pic
    O.C., Oregon
    921
    Where's the pic?????
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    Lewiston, N.Y.
    1,477
    Hmmm, let me try again
    Lewiston, N.Y.
    1,477
    also, i have a black clamp that is supposed to hold the cable but the only area it seems to fit is over the fork boots? I did a forum search with no avail. and i def
    dont want to mess anything up!
    Baltimore, MD
    6,088
    The black clamp should fit over your lower fork leg. It keeps the cable securely against the leg so it doesn't get tangled up in the moving wheel and tire and it keeps the gearbox from moving around so much. Some movement of the gearbox is normal. If the black plastic clamp doesn't fit over your fork leg, then it's the wrong clamp.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Lewiston, N.Y.
    1,477
    Pat - here are the pix of the clamp and the red thing. I have no idea what the red thing goes to??
ID:	133892Click image for larger version.
Name:	RED THING!.JPG
    Baltimore, MD
    6,088
    The red piece bolts onto something to help keep your speedo cable from getting tangled. You may have the black plastic clamp from a 250r or 350x, not sure about the diameter measurements of the lower legs. And I just found my box of what little bits I have left, it looks like you are missing a little rubber piece that goes inbetween the fork leg and your clamp. I seem to have one. How much is it worth? A million dollars? LOL Pm me your address and I'll send it out in the mail to you. It makes a complete 350x used speedo kit go up in value though!!!!!! LOL
    Nicholson 185s
    May 2009
    monroe, Louisiana, United States
    948
    there should be rubber piece that goes in the clamp which will take care of that gap, and the red bracket bolts to the fender to hold the speedo cable also, same concept/thing as the loop on the other side of the fender for the brake cable. i just put one on my 85 200x about a month ago. i was like yeeeehaaaa i know the answer to this one lol.
    Lewiston, N.Y.
    1,477
    @ yooperman - could you please send me a pic of the red piece? Im not sure i follow you. A picture would be sooo much easier
    May 2009
    948
    yeah i will take a picture tomorrow of it for ya.
    NEPA
    7,048
    Yoopers correct on the Red plastic,it simply bolts onto your fender. It's OE Hondaline,,so don't let it bother you TOO much! I think your TAB is missing from your fr hub as to the reason you originally posted. The gearbox should only move a little bit,the tab on your fr hub holds it in place.
    Lewiston, N.Y.
    1,477
    tab on the front hub? isnt that what turns the gearbox wheel? i dont see how it could turn the wheel and hold it in place at the same time...unless im not understanding ya?
    May 2009
    948
    here are the pictures for ya man hope they help, there not the best did them on the wifes phone and i am not to hip on the whole computer mumbo jumbo lol
    Lewiston, N.Y.
    1,477
    so it looks like i have to drill the plastics? Either way thanks for the pics! That was much help. Vealmonkey was nice enough to send me the rubber insert for my clamp. Its awesome to have good friend!
    Lewiston, N.Y.
    1,477
    i also have a 250r fender on it so i dont know if that red thingy is gonna make it on now that i think of it.
