Results 1 to 7 of 7
Thread: What Keihin Carb is this?
    Sep 2011
    Monroe Louisiana
    73
    I acquired this carb in a bulk trade some years ago and I ended up not needing it. Can anyone tell me exactly what it is, what machines it will work on and how much its worth on the used market? Thanks!
    Mexico
    9,014
    Quote Originally Posted by daBIGKAHUNA View Post
    It's a old Keihin PE, but I don't know what that 37 means as it seems the standard size for the largest PE is 38mm. If no one else here knows, measure the I.D. of the small end of the carb where it connects to the engine to be sure. It appears to have been bead blasted and there are screws missing and that's enough to scare me off without being able to open it up and see what all got blasted. As far as what it will work on I'd guess (if it is a 38mm) any larger single cylinder engine. It likley started life on a Honda, but I'm only guessing. As for what its worth, a new 38mm PE sells for around $170, but being used and "messsed with" I'd guess you'll be lucky to get over $40. Good luck.
    Aug 2004
    Cedar City, Utah
    474
    If its a 34mm its stock for an 85 250R. HH
    Sep 2007
    100mi west of Chicago
    3,582
    ^^That looks like what it is, the service manual lists 85 250R carb as PE37A, 34mm
    Rob
    Strathmore, Alberta
    146
    That looks like my exact same one on my '85 250r
    Sep 2011
    Illinios
    149
    Yep that's an R carb, look at the choke
    Sep 2011
    Monroe Louisiana
    73
    Thanks to all for the verification.
