Results 1 to 15 of 25
Thread: Has anyone ever honestly cleaned their centrifugal oil filter?
    Pacific NW
    4,255
    They say it's a regular maintenance issue for the 90/110 types.
    I must be running out of things to fix or worry about.
    Thanks
    Dec 2007
    Quebec,Canada
    1,013
    the 200 too use this kind of filter....it's a good thing to clean it when you have to remove the clutch cover to repair something,but most will not remove the cover only to clean it
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    1986 ATC250SX FATCAT
    Aug 2011
    Stewartstown, PA
    73
    I have a 200s wich like 500x has a centrifugal filter. I have not cleaned it since I picked it up a few months ago and I know the guy I picked it up from never did. And he had it for 4 years :o but I do think I'm going to go ahead and clean mine soon.
    Dec 2010
    S.E. Illinois
    1,178
    my 125 has one and yes i checked the filter when i first got it. suprisingly it was very clean, but then again the old man that had it before me kept it serviced every year.
    74 HONDA ATC 70
    Sep 2009
    Suring Wisconsin
    967
    I put a new clutch in my 86 200x this spring and had the drum off. It was very clean one or two flicks of greasy dirt. That was the first time it was apart since new. I have parted out lots of atc's and 4- wheelers and only ever seen one out of 20+ that was dirty. It was one that had been swamped and filled with muddy water. I would not pull it apart just to clean the drum.
    Sep 2007
    100mi west of Chicago
    3,582
    I agree, I cleaned mine just because I had it apart. There wasn't much crud in it.
    Rob
    Qdude79 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    CenCal
    369
    Only on my rebuild. Clean.
    Nov 2010
    Oshawa, On, Canada
    2,123
    My 125m has been driven daily since new in 1984.
    I just cleaned that filter... There was not a spec of anything on it. Useless...
    Aslong as you change your oil before it gets dirty, you would have nothing to worry about.
    Jason
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Jun 2009
    Leander TX
    2,217
    I had an 82 110 engine and a 79 90 engine apart last year. They had the nasiest crud in the centrifugal filters. I mean, 3/8" build up. Nasty. Also, both engines had black sludge int he bottom of the crankcase so that's a pretty good indication of the lack of care they got.
    Jul 2011
    Eau Claire, WI
    1,188
    Is that the little screen above the drain plug?
    ^ No, it runs off the crank. I've seen some filthy and others just a bit dirty. I change oil often so I don't make a big deal out of getting around to it....
    NEPA
    7,049
    Quote Originally Posted by Jason125m View Post
    Jason
    I'm a little curious if Everyone in this thread is talking about the same thing.. He's talking about the centrifugal oil "filter" 3 locktighted screws,on the crank,,and generally they are PACKED full of gray grime!!.. Now,,granted,,I'm used to seeing customers machines,,getting rebuilt,,that have been neglected. But I have never seen a clean one! EVER! . Are some of you talking about the screen in the bottom of the case? Just curious!! Yes,,Doc,,clean them badboys out! Heat around the screws Carefully to loosen the locktight.. Then impact,,that's how I do them anyhow.. Not saying I NEVER broke one,,or two.. I stil can't believe Honda designed this???!!! NOWDAYS,,I would believe it in a heartbeat!!!
    Dec 2010
    S.E. Illinois
    1,178
    atc007, i'm talking about the one inside the clutch, not the lower flat screen.
    74 HONDA ATC 70
    Jul 2011
    Eau Claire, WI
    1,188
    I don't recall seeing this in the manual or the parts diagrams.
    NEPA
    7,049
    Quote Originally Posted by Jon Boy View Post
    You've got a very well maintained machine then!! As you already said!
