Results 1 to 12 of 12
Thread: how would i put a ciggarette lighter on my big red?
    chuckiedog04's Avatar
    chuckiedog04 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2011
    minnesota
    369
    okay, so i have a 85 250es, the plug upfront by my headlight is being used for my heated grips (might remove, they seem not to work anymore.). so i was wondering how i would go about putting a cig lighter on my big red with minimum work? It would give me a lot of options if i had one.
    Jan 2011
    Brazil, Indiana
    2,087
    ditch the heated grips and buy thicker gloves. Either that or run them both off of the same wire, but you probably would have to make certain you only ran one at a time. Depending on the demand from the accessories you are running, you might be able to get away with two at a time..
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Mar 2011
    minnesota
    369
    I just looked on ebay, it looks like i can get a cig lighter that goes straight from the battery. atleast thats what it looks like, i've never messed with this type of stuff so its kind of a new thing to me.
    Dec 2010
    S.E. Illinois
    1,178
    buddy has his set up like this for his. mainly used for portable pump. has the neg. grounded and the pos. wired to the ignition. so it works key on only.
    74 HONDA ATC 70
    Pacific NW
    4,255
    I found what they now call a 'powerpoint'
    which is more politically correct than cig lighter.
    It was over by all the accessories like cell chargers
    I think it was like 6 bucks.
    I bet a truck stop or RV supply place would have some really cool setups.
    Apr 2002
    s.w. michigan
    6,498
    I put a cigarette lighter on the previous 85 Bigred I owed. Purchased the lighter + holder package from local hardware for under 10 dollars.
    Cut the 2 wires going to the tee~ totally useless Honda "accessory" plug and after unscrewing that "thing" threw it in the trash can.
    Mounted the hardware brand lighter (that can be had at about anywhere where they sell more then 12 items),, my concern was wether I would need to increase fuse size ~ nope.
    Kept the same OEM fuse and lit many a smoke while under way AND for the politically correct way of saying, as far as I am concerned, the only reason open face helmits are still for sale (for smokers like me).
    I am putting a cigarette lighter on my shopping list for my current Bigred ride. Can't dam beleive I hadn't put one on long ago on my Bigred, like I done on the other one.
    Pacific NW
    4,255
    I just got those waterproof magnesium chunks with the flint striker
    for 2 bucks each at HF.
    Those will stay in the trunks of all the trikes in case someone gets really stuck
    somewhere.
    They'll ignite in any weather.
    I remember an old harley with the cig lighter in the gas tank.
    As far as extra juice, I've heard that lawnmower batteries fit nicely in the big red trunks.
    and they're surely on sale this time of year.
    For more intense stuff,
    HF has a 12 volt powerpak with jumper cables.
    inverter for 120 volts ac, and 2 - 12volt cig lighter plug ins.
    I hit one of the switches and it has an air compressor and a light.
    Lead acid battery that wants an initial charge of 48 hrs at 500ma
    likes to be kept between 13-15 volts and can be charged from the dc cig lighter in a motor home
    or car/truck. and regular house current too.
    59$ and it ran my little tv for 3 days when the power was out.
    Dec 2010
    845
    I had a power point (cig lighter) on my 200es don't know if Actually worked sold it before i even tied
    MY TRIKES! :
    1- 85 250r NOS engine
    1- 1985 350x
    1- 82 250r + Parts
    1- 86 250es Big Red
    1- 85 200x
    2- 84 200es Big Red
    1- 84 200M !!MINTY!!
    1- 73 Atc 70 (project)
    MY Snowmobile's!!
    1999 Polaris Indy 440
    1999 Ski-Doo 583
    1993 Polaris Indy 500
    My Dirt Bike
    1986 Dr100
    Maryland
    3,077
    Only you can prevent forest fires.
    Jul 2011
    Lilly PA
    1,480
    I thought that the open face helmets were for ppl that chew snuff (like me) so we dont spit on the inside of our mouth protector. Ha ha, I smoke too so they are win win....I think! Cig lighter would be great for spotlight to or do you think it would pull too much juice??
    Mar 2007
    Hampshire U.K.
    536
    Zippo and duct tape?
    ATC 70, ATC 250es, 1/32 ATC 250R
    1 person in 10 understands binary, the other one doesn't.
    Trikefest UK '08 survivor!
    Oct 2007
    Minneapolis mn
    4,067
    Bic... I just tagged mine off the factory power port on the front of my ES... (never used it yet...)
