Carb issues on 250SX
Hey guys looking for some opinions...
I can't get full throttle on my 250SX...it bogs badly, if I ease it it does ok....and on low end it stubles at light throttle just off idle and sometimes dies...I moved the clip all the way to the lean end...the air screw is out 2.25 turns...everything is tight...the rebuild kit I bought was from Moose...reading thru the posts they aren't real popular..lol.
My questions are...who's carb kit is recommended? What jet size is stock? (the bike is bone stock except for the Moose air filter) and where is the stock clip setting for the needle (I'm assuming it's in the middle) but figured I'd ask.
The owners manual also said something about syncing the carb, but it doesn't say wether you should set it with the throttle all the way closed (idle screw backed all the way out) or after the idle is set.
I think somebody has had the carb off and apart before I got it (hence the questions)...the little plastic baffle plate is missing also...but I don't ride that hard to worry about it...maybe it's time for a manual....lol
1985 Honda 250SX
1991 Suzuki LT230E
1970 Sierra Trail Boss 6X6 (under restoration)
