Originally Posted by
bhillis99
Ok well i have searched but nothing really on what i asked. I will get either barnett or oem, dont want to have to do this job again.
I was reading my maunual and it says there are a couple of small orings that could be replaced, so I was just wondering if anyone has seen anything that the manual doesnt cover
You need: Clutch set, side cover gasket, 27mm socket, impact wrench and standard hand tools..
Disassemble as per the manual until you get to the special tool part to remove the clutch basket. Then punch out the detent locking the clutch basket nut, hold the basket with your hand and spin the nut off with the impact..
Soak the clutch in oil prior to disassembly, swap the old for the new and put it all back together again..then change your oil and filter when you are done to ensure you didn't leave any dirt in the case during your work..
Oh yeah, don't break shlt while you are doing it..remember the old lady is 25 years old!!
This is a verbatum description(more or less) that DC , the resident demi-god, posted before when I did mine..
Easy as pie..done in about 1.5 hours..
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
