Got new clutch cover, removed old. Unfortunately.....kicker cover and right side case were also cracked So....while I debated the Tri z's destiny over several beers...I decided to go a bit further than originally thought. Found new right side case, kicker cover as well. Gonna probably need a new shift shaft, pretty bad shap also. Looking at a possible Hot rod crank...new piston and rings. Ordered gasket kit and a few other things as well. Figured might as well with it tore down this far huh?? Raffa.....keep an eye on your porch It is a sad scene right now but you gotta' break eggs to make mayonaise right? Gonna get the shock rebuilt also as well as go over the front forks.
