Results 1 to 9 of 9
Thread: Plastic gas tank leaking
    Pacific NW
    4,255
    ahhh, my first no rust plastic tank and the sucker literally pours gas out from under the cap.
    I cut a new gasket for the cap and put it under the rubber seal
    with no change.
    Still sloshes out bad.
    I hope the neck isn't separated from the tank but it's real hard to see.
    I found another cap that says 'clark' on it but the threads seem different.
    Got too dark to fool with it anymore tonight.
    So I guess my questions are,
    -what kind of glue or sealer works on plastics if it comes to that.
    -It's an 85 sx so I know those tanks (metal or plastic) are superspecific
    so not too sure what options I have
    metairie,Louisiana
    48
    i 2 82 200 with the same tank and it leaks out around the cap like yours i do not know why
    May 2011
    eden,ny
    3,481
    i had the same problem with chinese atv. I end up putting teflon tape on the threads. it worked but I had to change the tape every now and then
    Dec 2010
    845
    I heard so platic tanks are junk
    MY TRIKES! :
    1- 85 250r NOS engine
    1- 1985 350x
    1- 82 250r + Parts
    1- 86 250es Big Red
    1- 85 200x
    2- 84 200es Big Red
    1- 84 200M !!MINTY!!
    1- 73 Atc 70 (project)
    MY Snowmobile's!!
    1999 Polaris Indy 440
    1999 Ski-Doo 583
    1993 Polaris Indy 500
    My Dirt Bike
    1986 Dr100
    Oct 2007
    Minneapolis mn
    4,067
    Would it work to put an o-ring up under the cap, where it meets the tank neck?
    glendive, montana
    1,822
    I'm guessing that the threads were too sloppy on it to help create a good seal sorry about your luck drjoe. Damn that rotten aftermarket stuff
    OK
    5,450
    Is it a Clarke tank?
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    nicker71's Avatar
    nicker71 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Wright City, Missouri
    385
    clarke tanks have a cork gasket that keeps them from leaking. Once its gone they will leak badly. I was lucky and my stock cap fit mine. I'd give a call to the tank manufacter and see what they can do.
    Pacific NW
    4,255
    Lucked out.
    Found a red funnel used for filling coleman stoves and it fits in there perfectly
    so I cut it off flush with the fill rim and it now acts like that sleeve that's in all the metal tanks.
    Ya know, that sleeve inside the fill port that hangs down an inch or so,
    keeps us from draining tanks completely but also keeps splash from hitting the cap
    directly.
    That funnel is just tapered enough to fit in perfectly and that by itself was almost good enough.
    No leak and a built in fuel filler filter. :-)
    Not sure if it's a clark tank but a clark cap spins on perfectly, and the cork is still there.
    Gotta get lucky once in a while, eh?
