Results 1 to 8 of 8
Thread: 200M sprocket Interchange with a 200s?
    Brandon, Manitoba
    2,209
    I just got home from a fishing trip in northern MB and I took my 200s up there with a home made wood trailer to portage into the lake. The trike worked great for it but it would be a lot better if I was geared down because it worked pretty hard.
    I want to go down from a 11T front sprocket to a 10T so I dont have to get a new chain, but I cant seem to find one, so the next option is go bigger on the rear sprocket.
    Stock gear ratio is 11/43.
    I did the math and a 10/43 gear ratio is equal to a 11/47 gear ratio.
    I can get a 47T rear sprocket that fits a 200m, just wondering if it will fit a 200s.
    Also anybody have an idea of how much bigger of a chain I should get? Stock is 84 links
    Heres some pics from our trip! Have you ever seen a trike in a boat? A little nerve racking!
    Attached Thumbnails Attached Thumbnails 246806_10150623753395261_873710260_19050424_5358945_n.jpg   249598_10150623743855261_873710260_19050218_2729468_n.jpg   250559_10150623743190261_873710260_19050202_5553202_n.jpg   253397_10150623752760261_873710260_19050409_6661333_n.jpg   254829_10150623748825261_873710260_19050322_6379865_n.jpg   254913_10150623743430261_873710260_19050209_5864567_n.jpg
    Brandon, Manitoba
    2,209
    anybody have an idea about this? thanks!
    glendive, montana
    1,822
    they should match right up if there is room in your chain guard for it, not much difference between a 200's and a 200'm. I would double check to see how much room you have before buying and attempting to install, so you don't have any issues
    Dec 2007
    Quebec,Canada
    1,013
    will not fit,they are different,check microfiche.....
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Brandon, Manitoba
    2,209
    Are you sure the part number isnt differant just because its a differant size? I want to go to the 47T sprocket instead of the 43, I dont have a chain case anymore..just wondering if it will bolt on.
    Dec 2009
    BFE
    1,202
    I looked all over for a 10t front sprocket for my old 200 and didnt fine one on my own so I went to my local shop and they was able to fine me one some how idk what it was originaly for but it looked just like a stock sprocket and worked great. You could actually tell a big difference in power. You could make yor own sprocket too. A guy on here not to long ago made himself a 8t front so he could turn some 27 inch tires!
    "I'm Kind Of Like The Turtle Man Of 3Wheelers."
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    Brandon, Manitoba
    2,209
    https://www.atvworks.com/products.asp?cat=46&pg=2
    Just searched google and found this site.. ordered a 10T front sprocket
    XSP103 ATC 185/200 10 Tooth Front Sprocket
    10 Tooth Front Sprocket.
    Fits:
    ATC200M 84-85
    ATC200 1983
    ATC200S 84-86
    ATC185 1980
    ATC185S 81-83
    Price: $9.95
    Grande Prairie, Alberta, Canada
    96
    I'm not sure about which models have which. But I know some 200s have a five bolt, internal damper sprocket and some have the more modern 4 bolt with the bushings that surround the bolts and they are not interchangable. Unless you were to swap the axle as well.
