Results 1 to 10 of 10
Thread: Dies for tight spots?
    texas
    567
    Does anybody make a die that is the size of a nut? I need to fix some threads in a really tight spot that nothing can get to but a nut. Its an m8x1.25. My die is a whole inch and thats way to big.
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    Never seen anything. you may be able to grind the die down, i knwo the outsides of a die are all made the same size regardless of the thread so they all fit into the same die handle.
    texas
    567
    http://www.autozone.com/autozone/acc...er=391372_0_0_
    Has to be somthing. There in this set but dont have 8x1.25
    Scootertrash's Avatar
    In the sticks
    4,638
    Sears has this one that has an 8X1.25 die:
    http://www.sears.com/shc/s/p_10153_1...2&blockType=G2
    I bit the bullet and bought a set a few years ago. It has come in handy more than I ever thought it would
    Mar 2005
    ma
    988
    Quote Originally Posted by 300rman View Post
    there is different od size dies and handles. theres 13/16", 1", 1 1/2, 2", 2 1/2", 3" and probably bigger. theres also hex dies.
    best thing you could so is get a hex die and use a socket to run it down the threads.
    http://cgi.ebay.com/M8-X-1-25-CARBON...item45f7b98dfb
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
    In the sticks
    4,638
    The set I posted above sblt's post are indeed hex dies, but they are designed to repair a damaged thread, not cutting a new one, although I have used a regular die for repairing a damaged thread. sblt's link would be much cheaper route to go. I bought the set because I do enough wrenching where a full set came in handy.
    texas
    567
    i ended up pulling theader and clean all the threads on my 350x. just wish they made dies the size of a nut
    Aug 2005
    Lockport, NY
    2,395
    They make chasing nuts that are just that, the size of a nut. You can get a whole set at sears and likely harbor freight
    http://cgi.ebay.com/METRIC-THREAD-CH...item20ba220d96
    texas
    567
    i didnt know what they were called lol thanks
    In the sticks
    4,638
    Same thing I had in my post, but the link was bad. Link has been fixed, but here it is again (sears rethreading kit):
