A good place to start would be to get yourself a honda shop manual for your trike. They are invaluable to help you keep up repairs and maintenance. The rest is sort of common sense. Brakes need adjusting. Cables need lubed. Front and rear wheel bearings need checking for rolling resistance and excessive wear. Chain needs lubricated and adjusted to the correct tension. You have a spark plug that needs gapped and periodically replaced. You have an ignition that needs to be checked and kept in proper timing. You have valves that need to be adjusted to maintain the proper valve lash. You have oil to change and a filter screen to clean. You have lights that may need periodic replacement. And you have painted surfaces to wash and occasionally wax. But yourself a nice helmet and make sure to wear it, especially just starting out. There is a clutch to be adjusted as well, even though you don't have a clutch lever to use, because the clutch is tied into the shifter, so as you move the shifter up and down to engage the gears, it operates the clutch, so you have a semi automatic clutch. Don't put your foot down in turns. Be cautions as trikes can wheelie and flip over on you if you are not careful. Also in turns, you'll want to lean into the turn. Take your time and learn the basics. Once you learn the basics, then you can start going faster. Have fun. Ride safe. Wear your helmet. Best of luck with your new trike.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
