Results 1 to 15 of 19
Thread: Seafoam Motor Treatment
    Saskatchetoon Sk
    360
    Ok so I have been using seafoam in my fuel now for almost a year. I use it in everything that has an engine. I sell the stuff to at the auto parts store I work at lol.
    Now this stuff can be used in the engine oil as well. Its supposed to burn out any carbon that is in the engine instantly. I do know of people putting it in their cars and trucks engine with excellent results. Just wondering what if anyone has run it in the wet clutch system. I was thinking about doing a treatment with it and then just idle it for 10 min and dump the oil.
    While we are on the subject. Anyone run the Lucas stuff as well????
    1982 Honda ATC 200
    1984 Yamaha 225DX
    earth
    141
    ive used it in my 200x. in the fuel and in the oil. i road it around for about 2 hours then dumped the oil. i did not notice any adverse affects with the clutch.
    Raleigh, nc
    71
    I run it in all my bikes gas, as well as my corvette, because they sit awhile between rides. Works great. I have used it to flush old, bad oil in some abused bikes and never felt any adverse effects. As a matter of fact I feel that it helped free up a sticking clutch on a bike that sat for years.
    84 200s
    83 250R
    84 ATC110
    85 ATC110
    84 YTM200
    85 YTM225DX
    Saskatchetoon Sk
    360
    I use it in the gas on everything.
    Think I am going to try it on the engine now too. Was just worried that it might have some adverse effects on the clutch.
    1982 Honda ATC 200
    1984 Yamaha 225DX
    Aug 2007
    Colorado
    107
    Lucas is good stuff.
    I use Lucas ATF in the forks of my 85R. Lucas semi-synthetic 2 stroke at 36:1 burns clean and hasn't fouled a plug yet.
    Oct 2007
    Grosse Tete, LA
    3,440
    Don't use the Lucas stuff in your engine oil...good bye clutches.
    Yamaha ring free works better than sea foam but runs 30 bucks a bottle. But one bottle does 110 gallons or so. More for your money. I run a little ring free through the car whenever I get a free bottle. As far as fuel treatments in bikes, the only one I have running right now is my popo... And it gets less than 12 mpg when we get on it lol
    Saskatchetoon Sk
    360
    Quote Originally Posted by The Goat View Post
    Thanks for the info on the lucas!! I thought it might be bad for the clutches.
    Just realized that at work I can get the Rotella 15w40 everyone is talking about so now I am going to use that for engine oil lol.
    I get seafoam at a incredible price!! We sell it over the counter for 8.26 a bottle so I get better then that
    1982 Honda ATC 200
    1984 Yamaha 225DX
    Blossvale NY
    4,563
    Im not sure the 15w-40 is safe for wet clutches either. I use it in my diesel John Deere garden tractor and nowhere on the bottle did it say it was safe for wet clutches. Which I wouldnt really expect since it is primarily a diesel engine oil.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    NEPA
    7,049
    Seriously,and honestly. Has anyone here ,EVER ruined a wet clutch with a so called good oil. 1st hand,,not you heard this and that,or your brothers friend said... YOU put a top quality oil in an engine,and the wet clutches slip so bad you had to replace them! I wanna hear it!! I know 1st hand there are some incredible lubricants out there,I also know,,MOST of the general hype,,is exactly that.
    Saskatchetoon Sk
    360
    This thread says it all:
    http://www.3wheelerworld.com/showthr...o-types)/page5
    The oil has been used for many many years and a Factory Honda Racer is recommending it so I think it would be safe.
    As for regular oil wrecking clutches. Yes I bought a honda off my brother in law that had it for years. He ran regular cheap motor oil in it and it did ruin the clutches. So much that I had to change them.
    Bottom line most oils are no good for wet clutches. If I remember correctly it has to be SJ rated which Rotella 15W40 is.
    1982 Honda ATC 200
    1984 Yamaha 225DX
    Oct 2007
    Minneapolis mn
    4,067
    Quote Originally Posted by atc007 View Post
    Yep... I went cheap, Valvoline 10w30, non wet clutch oil in my BR, and it stated to slip right away afterwards... (granted clutch was 25 y/o) After the new clutch, its only wet clutch oils....
    Oct 2007
    Grosse Tete, LA
    3,440
    I slipped my 300's clutch running rotella. I wiped out a clutch in a 70 running mobile one.
    I don't skimp on my oils anymore. I run motul double ester bike oil in anything with a wet clutch, and castrol edge in anything without a wet clutch. My Polaris gets oem fluids, except for oil, then it either gets high end yamalube or 10w60 full synthetic.
    But yes, your clutches can take a beating from cheap oil.
    St. Agatha, ON, Canada
    1,497
    On the topic of oil, i went to my local Honda dealer on Wednesday and I was told to use 10W40, mineral oil, not synthetic.
    1983 Honda ATC 200e: my first true Man Toy!-Sold for $200 on Victoria Day
    Ice & Trikes 4 Life!
    If Nissan Motorsports = Nismo, does Honda Motorsports = Homo ?
    Kale is offline First Time Rider Arm chair racerNew to the board
    Jan 2011
    AB
    78
    ever tried vegetable oil? like canola or olive oil maybe? lol. just kiddin. never herd of putting mineral oil in clutches before, but just because i haven't doesn't mean it won't work tho...
    BigRed_Ryno is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    Kent UK
    311
    we've run my '70 for nearly 20 years now on what ever gloop was on the bench, Fully, semi, you name it, it would be put in it. we'd tow sledges, trailers an all sorts with it, an to this day its still on the same clutch. (tho we would get it well hot)
    ok i know they're not exactly power houses, but hell did we give it some abuse as kids, so I do wonder about this oil malarky. Im not sayin it aint true, but we've never had any issues. oh, an back on topic, I've never really used any aditives in the oil or gas, maybe as they dont get as much use these days i should...
