Results 1 to 13 of 13
Thread: 84 Big Red 200ES Hubs
    Nov 2010
    Canada, NB
    26
    I was wondering if rear hubs from a 450r or anything else would fit on the 84 big red 200es? The 4/150 pattern isn't too common, i can't find any spacers or aluminum rims, so i'd like to swap them out.
    Lauderdale County, Alabama
    2,029
    Hmmmm, lemme do some quick thinkin'.
    The hubs off of a 450R will also fit a 400/300ex IIRC, those hubs will fit an 86 200x. Hubs off of a '79 Odyssey will fit an '86 200x. Those hubs will fit on my 84 Red.
    The hubs should, but I don't think they'd fit the stock wheels.
    Attica, NY
    451
    the 200es has 24 spline hubs, almost all honda hubs are 24's. the 450's should slide right on, though you may have to use a washer as a spacer over the axle cone.
    WARNING: I'm About To Do Something REALLLYYYY Stupid!!!
    Past:
    '82 Honda 110
    '82 Honda 110
    '83 Honda 185s
    '85 Honda 200m
    '85 Honda 250sx
    '85 Honda Auto-X
    Present:
    '82 Honda 250r
    '82 Honda 250r (Basket Case)
    '83 Honda 200s (Parting out)
    '84 Honda 200x
    '84 Honda 250r (Basket Case)
    '85 Honda 350x (currently being built)
    '85 Honda 350x (waiting to be built)
    Future:
    '83-'87 200x's (wish list)
    '86 Honda 350x (eventually)
    Nov 2010
    Canada, NB
    26
    What would be the best hubs to use? I don't have any yet, i would be just buying them, but do they have different bolt patterns? I plan on using some of the block style spacers, 2.5" on each side, and then some aluminum rims, same size as stock.
    2,029
    Well, 400ex hubs will widen it out a couple inches.
    I don't trust axle extenders, they have been nothing but trouble in my experiance, and they make it a hell of alot easier to bend an axle.
    Nov 2010
    Canada, NB
    26
    Is it possible to get aluminum rims that are offset, so that combined with the hubs i'll have a wider rear end?
    2,029
    The 400ex hubs will widen it by themselves, it they fit the wheels.
    I've heard of people just turned around the wheels and widening them some like that.
    Attica, NY
    451
    honda 400ex/300ex/250x/450r, all these hubs are the same. they allow you the 4/110 bolt pattern. the wheel selection for this bolt pattern is numerous to say the least, big, small, wide, bead locks, etc etc etc etc.
    Past:
    '82 Honda 110
    '82 Honda 110
    '83 Honda 185s
    '85 Honda 200m
    '85 Honda 250sx
    '85 Honda Auto-X
    Present:
    '82 Honda 250r
    '84 Honda 200x
    Future:
    May 2008
    Pomeroy,PA
    86
    I recently bought some hubs for my 84 big red. They are for the 300/400 ex. They bolt on just fine. They are 4/110 bolt pattern. Compared to stock. They each move the wheel out 3/4". Adding a total of 1 1/2" to the width. Then got some douglas aluminum rims. 9x9 with the 6+3 offset.
    Total added width. 4 1/2".
ID:	122402Click image for larger version.
ID:	122404Click image for larger version.
    acidburn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Cornwall
    344
    just dont do like the idiot that sold me my trike did, weld the hubs on..
    Nov 2010
    Canada, NB
    26
    I like your setup trikeman! Are your wheels still 25 inches? What kind of tire did you use? I've been looking for 12x9 rims but I haven't found any, I wanted to use the tires I already have.
    NEPA
    7,049
    He is running 9x9 rims with 25-12-9 tires.
    Nov 2010
    Canada, NB
    26
    What other rim sizes would fit 25-12-9 tires?
