Results 1 to 14 of 14
Thread: 83 Big Red Gas Tank Leak - How do I repair it?
    Aug 2010
    Wisconsin
    24
    After a day of riding my restored 83 Big Red and parking it in my garage, I smelled some gas and noticed a very small amount had leaked onto the floor. I traced it to under the tank, at the welded brackets that rest against the rubber bump-stops on the frame. This is the first time it started leaking so I guess the bouncing around during my ride caused a stress fracture at the weld or something. I can't actually see the hole or crack but can narrow it down the a specific area on the weld. The tank was stripped, painted, & clearcoated and all new decals were applied so I don't want to do anything that would harm the finish. I don't think that will be an issue since the leak is underneath. I'm not sure how to fix this. Can anyone offer any suggestions?
    Cold Lake, Alberta, Canada
    3,019
    I used a tank sealing system called POR-15 on my BR. Cost about $75.00 in Canada for the three bottles of chemicals and coating. Works great if you follow the instructions. There are other products out there that other forum members swear by; Red Coat(sp) is one of them. Try the search feature on here and it should give you an idea how common this problem is. Good luck.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Apr 2010
    pa/washington county
    20
    i had the same problem on my 84 big red. the seams on each side started to weep fuel.replaced the metal tank with plastic one.ebay item for 85.00.
    250Eddie's Avatar
    250Eddie is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Miami,FL
    395
    you can use some JB weld thats what my dad did on his old tank and it worked u can also sand it and paint over it w/o a problem.
    87-250sx
    86-300es Big Red,The Beast
    85-250sx Tiny SwampThing
    85-250es Big Red
    84-70 ( My Sons Bike )
    Aug 2010
    Wisconsin
    24
    JB Weld was my first thought, well basically my only idea. I've been reading on other post about gas tank putty also. Anyone know which is better, JB Weld or "gas tank putty".
    I did consider a chemical liner as COOLPOOL suggests. But, I've seen some turn out REALLY bad and there is not much you can do about it if you don't get it right the first time. And, this is a moderate restoration bike so as PAUL suggests I want to keep the original tank on it.
    250Eddie's Avatar
    Miami,FL
    395
    if u use jb weld u gotta let the tank dry and put it there leave it for 2 or 3 days getting sun so it fully drys and ull nvr have to worry again about it , also make sure u sand down the area gonna put the jb weld on so it grabs on right.
    87-250sx
    85-250es Big Red
    Buck Snort's Avatar
    Buck Snort is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2011
    British Columbia
    398
    I had a small leak on my big red tank. I used the gas tank putty and it has stopped the leak. But i have not been for a ride since the repair.It is very simple to use and does seem to have a strong bond.
    The Open Road
    4,736
    I use Redkote or however it`s spelled
    It was $40 for a quart and that would do a couple tanks easy... I went the extra step and let it dry in the tank for a couple weeks before adding fuel but I think they suggest much less drying time...I think more is better
    Whatever you do.....Don`t get Redkote on the paint job....take care to get it all in the tank and not on it....it comes off but will leave a mark in the finish
    IMO, since you don`t want to mess with the nice new finish on the tank, after coating it, add a little more a couple days later and tip the tank with the leaky area DOWN just to be sure it sits over the leak giving a good seal since its in a tough spot that you might not reach from outside with putty or JB
    is it leaking from under the tab or next to it ?
    osoyoos bc canada
    1,057
    the best way to fix it is brazeing if you want to repaint after ive tryed the 3 stage thing and i can get pics of what it will look like in two years it seems great at first then it starts to peel off a clog the crap out of every thing the one cemical for getting rid of the rust is awsome after i took it out of the tank i put it in a bucket and dipped a chian that had been buryed for years there wasent much left but there was no rust
    Mar 2011
    83537 Idaho USA
    11
    I have used JB weld and some putty type epoxy that was sold at an auto parts store specifically for fuel tank repairs. Both worked very well, and the repairs lasted for years. Gotta get down to bare metal so they can bond to it though.
    I used the 3M rubber type coating on the inside of a Suzuki GT500 gas tank once, and wasn't happy with the results. It leaked again after about a year. It was expensive too.
    osoyoos bc canada
    1,057
    [QUOTE=
    I used the 3M rubber type coating on the inside of a Suzuki GT500 gas tank once, and wasn't happy with the results. It leaked again after about a year. It was expensive too.[/QUOTE]
    thats the crap i was talking about good luck keeping the carb clean ill never get that again
    Pacific NW
    4,255
    I had 2 early bigred tank fractures and one got fixed (welded) at a radiator shop and the other
    by some retired welder guy I found on C List.
    Aug 2010
    Wisconsin
    24
    I went with the JB weld method. I sanded the paint off with a Dremel. Used three coats of JB Weld over the seam that needed repairing. Then let it dry for three days before adding fuel. Two days and no weaping fuel....
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    i had jb weld on my 200s gas tank and it didnt hold, id cut the bracket off and bronze where ever is leaking, then mount the bracket back on. thats what we did to my 200s tank but then i switches to a 200m tank witch is bigger
