Results 1 to 15 of 20
Thread: Underglow kit on my 1985 atc 250r
    Leonardtown, MD
    594
    Well, I wanted to do something unique to my bike. So i got a pretty cheap ATV underglow kit and put it on my 1985 atc 250r. Its kind of dorky, but its neat.
    Here is a pic of the bike.
    Here is a walkaround of what has been done to my bike and some of the different color combos.
    If the imbeded link does not work, here is the direct link
    http://www.youtube.com/watch?v=1XzK1DTgELE
    I put a battery that powers the underglow kit in the airbox. The battery is so small that it doesn't even touch the air filter.
    I then drilled a small hole on the underside of the airbox that allows the positive and negative wires to route to the underglow control box.
    Next i mounted the underglow control box to the airbox by drilling two small holes and bolting it onto the airbox.
    Finally, i mounted the six light strips all around the bike and routed the wires to the control box. I will admit that the routing of the wires could be better, but its fine for now.
    I think the kit is pretty neat. I believe there is around 30 different color combos and i can control the changing of the colors with a wireless remote.
    My Rides:
    1985 ATC 250r
    1989 Suzuki LT-160
    Beaver Falls, PA
    2,666
    The light kit is cool... would be awesome for night trail riding. BTW, I think your grab bar is mounted upside down...
    Apr 2010
    central minnesota
    462
    Ive been thinking about doing that for awhile, Looks good man. Where did you get the kit from, I like that your able to change the color if you want! You should go out and do some more video when its a little darker so we can see the full effect of the neon!
    plymouth,il
    1,231
    you can hang that baby on the christmas tree now.
    Life is better on 3 wheels
    1984 200es big red
    1976 suzuki rm125
    1983 honda 250r (minty fresh) SOLD
    1986 honda 350x (A PILE....for now)
    197? honda 90 (pauter framed little beast in the making)
    Lauderdale County, Alabama
    2,029
    Hang?
    You sit it up on it's tail and decorate the trike.
    plymouth,il
    1,231
    hehe that'd work too.
    1984 200es big red
    1976 suzuki rm125
    Utah
    644
    Looks cool. Would be lots of fun on a night ride.
    A few wheelers, + an
    '73 Honda 49cc Mini Trail
    '85 200 Big WHEEL
    "Despite the cost of living, its still popular."
    BiGDawG's Avatar
    BiGDawG is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Millington, Michigan, United States
    384
    i got a bunch of green led strips i was thinking about doing this with but my trike don't have a battery, so if you don't mind sharing your info what type of battery did u use?
    Leonardtown, MD
    594
    Quote Originally Posted by oldtoys72 View Post
    This is where i got the kit
    http://www.ledunderbody.com/atv-quad-led-light-kit.aspx
    Quote Originally Posted by atc350xer View Post
    You know, i've been thinking that it is mounted upside down too. I will have to switch it around.
    Yea its pretty cool riding at night. Its so bright that ii don't need to use my headlight at night.
    Quote Originally Posted by BiGDawG View Post
    I measured the space available in the airbox and went to autozone thinking that they might have a motorcycle//jetskii/ATV battery small enough to fix in there. What do you know, they did. I will get the battery P/N tonight and take a picture of the set up.
    My Rides:
    1985 ATC 250r
    1989 Suzuki LT-160
    Northern NJ
    706
    I think thats pretty cool. Now you just need a sireeen or a mega phone. Then you can say Just walk away! Just walk away.. (mad max)
    Beaver Falls, PA
    2,666
    Do you have to run it off the battery, or could it be hooked up to your headlights? LED's draw almost nothing... This would be sweet on my 3fiddy!
    Leonardtown, MD
    594
    I'm not sure wither it can be ran off the bike itself. I have also heard that LEDs do not take up a lot of juice.. I didn't want to tap into the harness and mess anything up so i choose to just run it off a battery.
    I tried to splice a new backup light onto my suzuki LT-160 wiring harness, and i kept blowing fuses... maybe the same thing would happen if i tried to splice the LEDs into the 250r harness. I'm no electrician, so i have no idea.
    My Rides:
    1985 ATC 250r
    1989 Suzuki LT-160
    Central illionois
    164
    Thank god u talked in tht walk around! I haaaate quiet walk arounds! And how much weight does tht add to the r? And wat colors can I get?
    Leonardtown, MD
    594
    Weight..hmm.. less then 10 pounds? Including the battery. The kit is really pretty light.
    Here is the battery that i used.
    My Rides:
    1985 ATC 250r
    1989 Suzuki LT-160
    Dec 2005
    Wisconsin
    1,141
    With some small voltage regulators form Radio shack, and a few diodes to convert AC current into DC you could run a system without the battery and just use power from the stator.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
