Results 1 to 15 of 24
Thread: ATC 200 Auto X (How To Build an Auto X)
    Nov 2010
    Northern Illinois
    46
    After purchasing this 84' 200x for 300.00 and just letting it sit for a few months too long I found my brother in my barn dismantelling his mint 81' ATC200 with intentions of using the engine on my project trike. Well knowing that there was no turning back now I proceeded to help him take his trike apart. He sold his old trike body parts on ebay and that paid for the new 200x ones. The original 200x engine had been taken apart by the previous owner and never reassembled so it wasnt like my project was going anywhere. We had the entire trike stripped of everything but the rear swingarm in about an hour. The swingarm pivot pin(bolt) wont come out so we opted to leave it in. That made it really difficult to paint the swingarm and frame that were spraypainted the wrong red and ugly white scheme. We sanded the frame and repainted it the correct colors.
    The paint dried and a week later we got enough motivation to try and mount the engine. We used the stock 200x motor mounts with hardly a problem. By using the carb intake manifold from the 200x the x carb worked no problem. The airbox will mount the same way as the stock would fit. We used the entire electronics harness from the donor trike and made some minor modifications to get the new light to connect. Just match up the wire colors and your halfway there. We purchased new moose handlebars and mounted them. The gas tank that came with the 200x was in pretty good shape so my brother is pretty skilled at restoring them so he made it look brand new again, luckily there was little rust in the tank.
    The rear brake was modified to use the old chrome foot brake from the donor trike to activate the brake. The 200x motors have the foot brake mounted to the engine but the old 200's dont. We welded a bar to the 200x foot pegs to act as a pivot and attached a linkage to the foot pedal and master cylinder.
    New rear and front axle bearings made it roll straight again but that was after we found it was wobbling around the shop. In the process of doing that we found the hubs were from a 400ex and were sloppy on the 200x axle thus ruining the axle and hubs. Use the proper hubs please! New axle, new hubs, new tires and 8 x 8 stock rims from my trike since I got new 10 x 10's from ITP.
    DG Power 4 exhaust and the 200x carb with a 118 main jet works well with the 200x head and new pipe. I use a 15 main jet in my stock 200x with a Krome Power 4 from DG.
    To bottom it off we ordered new rear 18" maxis razr mx tires that still have to be mounted.
    To top it off we ordered new plastics all around from Maier Plastics for about 300.00 total. You need the mounts from the old ones! New decals from ATC Heaven made it pretty.
    Mistake 1: Sprocket ratio, get it right or your ride won't be. The stock sprocket ratio on the 81' 200 is 11/47. Don't go bigger in the front unless you have to and if you do just go 1 tooth. The rear should not change more than two or three either from stock. Any more and your performance could suffer greatly. I made the mistake of using the stock 200x rear sprocket with a 40 tooth front just to get it to fit at first. This has proved to be a waste of money. If you use a normal 200 atc as the donor engine you need to use a larger rear like the stock size. Something like a 45 tooth would work best on the 200x seeing as it has smaller tires.
    Mistake 2: Put the 200x head on the donor 200 bottom, I didn't at first and took the entire trike apart to bench the engine so that I could. While your at it and have the head off go one step further and remove the piston jug with the piston still inside and use that also on the 200 donor bottom. It's very easy and takes only a couple minutes. There are a couple pics here of me doing it. The 200x piston is higher compression and not using it if you have the parts would just be stupid and a loss of power you will regret not having.
    MORE UPGRADES YOU CAN DO:
    Use a 185s not 185 bottom end with 200x jug and head, a xr 200 cam and springs, and an xr200 carb even though you need to heat up the 200x airbox boot to fit it. Bikerchick on Ebay sells a high performance cam with .39 valve lift that requires new springs, and maybe a little grinding on the head (I might be wrong). The cam is only like 55-60 dollars and would be well worth it if you have your engine benched anyway.
    DONT FORGET A FULL GASKET SET!
    Attached Thumbnails Attached Thumbnails 1296014078231.jpg   IMG_20110305_230806.jpg   1296750109942.jpg   1296177756223.jpg   1299388088828.jpg   IMG_20110203_102216.jpg
    1299437818410.jpg   1297881293670.jpg   IMG_20110524_143038.jpg   IMG_20110514_200402 - Copy.jpg   IMG_20110524_142900 - Copy.jpg   IMG_20110524_143055.jpg
    IMG_20110527_112508.jpg   IMG_20110402_181550 - Copy.jpg   IMG_20110526_110953.jpg   IMG_20110515_154622 - Copy.jpg   vintage atc 200.jpg
    Southern MN
    1,875
    Are you going to do a step by step swap, with pictures? I know there has been a couple done befor, but that would still be fun to see. I always like to see what people come up with for the rear brake set-up, since the 200x used the brake lever on the right side engine case. I have 3 auto X's, and they are really great, especially in snow compared to the 200x manual.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Baltimore, MD
    6,088
    Yes, the rear brake pedal is probably about the only big thing on the whole trike. You can use the 200x wiring harness and everything is pretty much a plug in. I have a right side 200x footpeg set up for the rear brake reservoir somewhere down on the parts shelves.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    ontario
    1,131
    the auto x's are alot of fun, who needs brakes?
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    Jun 2009
    Leander TX
    2,217
    I used a 350x pedal on my Loncin powered 200x. The 350x pedal pivots on the 200x peg mount like it was made for it. Might need to be bent for auto-clutch case clearance but works great with the Loncin.
    Oct 2009
    lindenwold new jersey
    890
    I'm gonna be eyeing your build so pics please. This has to be the most popular conversion and well worth it as I"ve been told. I'm gathering the last few parts for my project auto X. So it's allways good to see what another builder is doing on the same project. Good luck with your build
    LIVE IN EAST PA. OR NEW JERSEY THEN CHECK THIS OUT www.njdirtriders.com SUPPORT LOCAL RIDING WITH US
    Jan 2011
    Brazil, Indiana
    2,087
    When I did mine, I drilled the mounting hole on the 200S brake pedal to 3/4" and ground some of it off so that it would fit on the bottom foot peg mount. Then I made a link out of a 1/4" bolt to connect it to the master cylinder linkage. I cut a little length out of the lever and bent it with a torch so it would be easier to find with my foot.
    Beaver Falls, PA
    2,666
    Nice work... I'll be starting my auto-x project soon(still need a donor motor). I plan on using a 350x brake pedal.
    May 2008
    Northwestern Ontario, Canada
    552
    Interested in this too! Just got a 200x and still debating on either a motor rebuild with the 200x or a auto swap. From what I hear the auto x is just as fun and a lot more comfortable to drive!
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
    Pacific NW
    4,255
    I think the big deal is the 200x kickstart gears.
    Depending on the year they are either not worth or impossible
    to fix correctly and 200 auto engines are everywhere and apparently
    and easy swap.
    The auto x was my first full suspension trike and the auto clutch
    is much more useful around the farm, tons of fun at the dunes
    and trails too.
    Dec 2010
    TX
    62
    excellent post. I just got done with mine today. What about the light wiring? Is yellow to yellow and the extra green wire to ground? Just want to make sure.(see photo)
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    man o man if i could find a 200x for parts id make an auto x out of it too, i got a 200m, 200e and a 200s bottom end for parts!!!!!!!!!!!!!!
    nicker71's Avatar
    nicker71 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Wright City, Missouri
    385
    I just finished my auto x conversion. I wanted to try out the auto motor to see if I liked it more than the x engine. I have custom front forks and 25 inch tires all the way around. I'll post some pics soon
    Mar 2011
    Coos Bay,Oregon
    I have wanted to build an auto x for my wife, I was thinking of putting a 200m motor so she would have electric start. has anyone tryed this? will it fit in the frame? or is the starter in the way?
    May 2008
    552
    Guys have put the "m" in, but apparently you have to either notch the front frame, or bash it in to get the starter to fit, but it has been done!
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
