Results 1 to 13 of 13
Thread: 350X headlight on 200X, Possible?
    Mar 2011
    Grafton, Ohio
    91
    Hi, I'd like to know if it's possible to run the 350x headlight on an 85 200x. i understand the mounting brackets would have to be altered, I was mostly wondering if the 200x lighting system can support the 350x headlights. I currently don't have a headlight, and I think the 350x headlight is a much nicer light to put on my 200x. any input would be appreciated.
    Sep 2007
    100mi west of Chicago
    3,582
    Aug 2009
    Gold Hill, OR
    594
    I know I had a 200x at one point with a 350x headlamp. I didn't put it on there though. I suggest going for it, it will probably work fine but if you need more power ricky stator FTW.
    When Three Wheelers Attack Productions:
    http://youtu.be/Bh_cvtxz7VQ When 3 wheelers attack
    http://youtu.be/KFONPvn8bzU When 3 wheelers attack: Part 2 (in HD, latest video)
    US-90 Video (now in HD on youtube!)
    "three wheelers don't kill people..... I kill people"
    Mar 2011
    Grafton, Ohio
    91
    Thanks for the input and the link. I'm still piecing this trike together, it was a basket case when I got it. I'll post a pic when it's finished
    Northern, California US
    105
    My 200x has one and it works great. You just have to wire both bulbs together into the switch. As far as mounting you use the little rubber straps on the 350x headlight.
    Crawford, CO
    28
    I have a 250sx that I'm installing a 200x front end on and I'm hoping I can install the 250sx headlight on the 200x because the 250sx light is bright. Last year I installed a automotive halogen light bulb and it's supper bright. I like the way the 350x headlight looks but man are they pricey on eBay, that's why I'll try to make the 250sx work since I didn't get a headlight with the 200x front end.
    As I walk through the valley of the shawdow of death I have no fear because I am the meinest MF in the whole valley.
    -Gen. George S. Patton
    http://www.youtube.com/user/strangefire1?feature=mhum
    torque's Avatar
    torque is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2011
    saskatoon sk canada
    308
    Quote Originally Posted by Dirtcloud View Post
    did you have to upgrade to rickies 75 watt stator.
    105
    No I just used the stock stator, but I can't remember if it had full brightness or not. Seems like only one light would work real good and the other one was kinda dim.
    Apr 2008
    Metro Detroit-MICH
    244
    Have mine done like this...
    Alex Stoli
    1986 Honda 250SX-X
    1985 Honda 200X
    1984 Honda ATC 70 w/ piranha 90
    1983 Honda ATC 70 w/ Pitster Pro E110
    TRIKEFEST 2011 vet
    SandPupi's 2011 vet
    Member #13036
    Apr 2006
    SE CA Dez in the sandbox
    892
    83-85 200X will not produce enough electricity for a 350X light satisfactorily unless you spend the money and get an aftermarket stator.
    I believe I've read that an 86 and up will run the 350X lights.
    Dec 2010
    washington state
    681
    you got to run one light as low beam and the other as high , adjust the aim of the lights , the stock stater wont run both at full brightness but if wired as stated they work great! good luck!!
    GOT MUD?:
    torque's Avatar
    Aug 2011
    saskatoon sk canada
    308
    Beaver Falls, PA
    2,666
    Quote Originally Posted by 350XJEDI View Post
    That is a great idea... now I know what to do on my auto-x!
