I just bought my first 250r and finally got it running sorta. I cleaned the carb several times and it doesn't help. We had to pull start it to get it to fire and then you have to keep on the gas at all times at minimum of 1/4 throttle. It has no take off power what so ever you put it in first and you have to slip the clutch a LOT and have to be on at least 1/2 throttle or more. It is extremly high geared feeling. I am not sure what stock gearing is but the front is a 14t and rear says 36t. Any one know what stock gearing is the front appears to be stock sproket but the rear is a sunpro. Thanks
