Results 1 to 12 of 12
Thread: Length of pull starter rope?
    Jan 2011
    mifflinburg
    525
    Honda 185s?? 1983.. i dont know how much rope to use and cant find in manual.. thanks so much guys...
    It says nothing in the Service Manual? Thats weird....... I'll have to look through it (hope I can't find it for your sake J/K)
    ATCrider42 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Iowa
    227
    The exact length is not important. About a 4ft rope will do. You need to make sure that the recoil has tension on it before you start winding your rope around it. Turn it a few times without the rope, then start turning it some more while feeding the rope around it. If your rope is longer this is better because you'll most likely end up with a tighter coil. If your rope is short, you will just have to turn it more times before you start feeding the rope around. Good Luck.
    Michigan UP
    1,005
    Hey DC when you find it want to let me know too. lol hahahaha
    Ironbnder's Avatar
    Ironbnder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alexandria, La
    363
    Quote Originally Posted by ATCrider42 View Post
    The notch in the pully is so you can wind it after the rope is in it. Why fight it with tension already on the spring. Tie the rope in it, wind it until it has good tension, let it pull the rope in and then cut the rope where needed and install the pull handle.
    FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
    86 250R
    86 350X
    87 250sx
    85 200x/cb350 custom
    81 185s/200x/250r custom
    79 atc 70
    Mini-Trail z50, 110cc Pit Bike
    and many multi-wheeled machines
    Nov 2006
    southern oregon
    2,338
    i usually use as much rope as will fit. I like to get a full pull without fear of the handle ripping out of my hand or snapping the rope..
    2-stroke lover
    Iowa
    227
    The notch in the pully is there so the rope stays attached to the pully and you don't just rip the rope right out when you start it.
    Ironbnder's Avatar
    Alexandria, La
    363
    OOOOOOKAY. Maybe you should read the manual. Or just keep doing it your way.
    86 250R
    86 350X
    87 250sx
    79 atc 70
    Jan 2011
    mifflinburg
    525
    Yea actualll i heard if u use a big rope it over cranks it and can damage.. Idk Hear say
    any way you can wind it up, Nice and tight about 9 or 10 turns or more clamp it to hold it. Feed rope threw and tie, Then slowly let the recoil of the spring slowly rewind it back in after u attatch the handle..
    Just wasnt sure if it will damage sumthing,, And 4ft will work? Because thats what i used..
    Ironbnder's Avatar
    Alexandria, La
    363
    Quote Originally Posted by Headsup View Post
    Yes you can, but that is the hard way. Look at your pulley and around the side will be a half moon notch machined in it. This is to fit the rope into so you can wind the spring after the rope is tied in and you do not have to wind and clamp as you say. Also you can add tension to a recoil without cutting the rope loose if it is a little lazy winding back in.
    I do not even know what to say about a big rope overcranking it.....???????
    Maybe Honda SHOULD explain this in the manual. I have never looked.
    86 250R
    86 350X
    87 250sx
    79 atc 70
    Jan 2011
    mifflinburg
    525
    okay yea thank you iron. Um not saying you are wrong, Just that this is the only way i have ever did it. I didnt know there was another way.. have to try it out i guess..
    Thanks again guys..For the overcranking idk hearsay like i said but, seems legit. idk what that would do though exept for damage to the pullstarter or spring itself..
    Nov 2006
    southern oregon
    2,338
    For the overcranking idk hearsay like i said but, seems legit...
    What seems legit about it? The pulley will only properly hold a certain length of rope.. and the spring will easily handle that...
    2-stroke lover
