Thread: whats the difference between an atc 200 and an atc 200s
    Jan 2011
    northern minnesota
    62
    my threewheeler is an 1983 atc 200, it says so on the original sticker, but i am finding alot of people calling it a 200s when it clearly is not.. what is the difference??? would love it if someone could clear this up for me.... thanks
    Sep 2007
    100mi west of Chicago
    3,582
    The 200 was made until 83, and then the 200s came along in 84. Styling is really the only difference. They are both chain drive, auto clutch engines with pull start.
    Rob
    Tionesta, PA
    5,740
    Here is the rundown of differences:
    Tires 200=25" 200s=22"
    Wheels 200=9" 200S=8"
    Plastics 200=2 piece with trunk 200s=1 piece with trunk
    200 had a larger front fender and a larger headlight
    frames are different
    airboxes are different.
    Seats are different - all 200 models had steel seat pans - all 200S had plastic seat pans
    Gas tanks are same - just different decals (Some early ATC200 models had a different tank due to the gas gap - but they are all shaped the same and are all interchangeable.
    Motors are interchangeable although 1985 and 1986 200S shift up and 84 S and all ATC200 models shift down
    different gearing
    Different tail lights
    (Note* 1983 ATC200 was the only ATC200 with front suspension - the front forks are interchangeable with the 200S and 185S, all prior year ATC200 had solid front forks)
    (Note* the ATC200s is much closer related to the 1983 ATC185S than it is to the ATC200)
    Jan 2011
    northern minnesota
    62
    you know i thought that that was the case, thanks for clearing it up for me.
    Jan 2011
    northern minnesota
    62
    sweet, thanks...
    Michigan UP
    1,005
    200s is plural meaning more than 1. lol I have an atc 200, or I have atc 200s
