Yup...just trying to get the project underway...and a lot of this is "new to me" kind of stuff.
Anyways...I trying to figure out how to save these old balloon tires. 3 of the 4 rear tires are structurally intact with small leaks, and a small center puncture. The rear tire with the best tread remaining has a 4 inch split across (tire with duct tape patch...just to see if it would hold air...enough to inflate anyways).
I've called a couple local tire shops that do agri-machinery tires...repair and reconditioning. The difference here is that I know what kind of repair work would permanently fix / save the tires...whereas they are very cut and dry in terms of the work they do.
I'm thinking...inject a quantity of molten rubber into the tire...roll / spin the tire to thoroughly coat the inside (with some bonding agent)...as one fix.
The other is to fill the tire with some Ecoflex polyurethane foam to simulate the 2.0psi tire pressure, and be done with it. The foam is described as "simulating the properties of a pneumatic tire" while still being flexible...not solid. Not sure about the weight issue though...not looking for 20 pound tires to roll around.
Planned on fixing the 4 inch tear using a thick rubber patch with lots of rubber bonding agent...maybe a more rigid patch.
If anyone out there has some experience with repairing / rejuvenating these old tires...please help.
Thanks again. You guys have been more than helpful so far.![]()
