My 83 110 dies intermittently. What does the gas cap on/off selector actually do?
I had it out on the ice on sunday and it would not run with the choke off. It also would die ever 4 to 5 min of running. So I switched carbs. Took it back out yesterday and ran better with the other carb. But it still dies. I would crack the gas cap and sometimes that was enough to get it running again. I would also pull the fuel line and let some fuel run out and it would start back up. The cap has a on / off selector on it. What is that for? Is it possible that fuel tank is creating a vacuum and it restricts fuel? The only thing I can think to do it take the cap off and put some plastic around the hole and put a hole in it for venting and see if that cures my problem unless someone else has a better idea.
1978 ATC 90
22mm Keihin carb
Ported intake/head
Performance cam
56mm 9.5:1 piston
110 cylinder/crank
110 cylinder/ timing chain
Front drum brakes
Brush guard
Complete rebuild to a 122cc
Complete frame off restoration.
$1400 invested
1983 ATC 110
22mm carb
Ported head/intake
Performance cam
56mm 9.5:1 piston
Complete rebuild to 122cc
$1000 invested
1984 200x
26 mm carb.
CR85 rear caliper
TRX hubs/rims
$871 invested
