Thread: 1999 arctic cat zrt 600 problem
    Oct 2009
    Ontario
    87
    I have a zrt and it takes alot of rpms to get it moving once it gets going it boggs down. i think it might be the clutch any ideas?
    Lots of Tri Moto parts for sale!
    Sep 2007
    100mi west of Chicago
    3,582
    Could be the clutch yes... Does it do it all all temperatures or only once warmed up? And at what rpm range does it do it at?
    Rob
    Sep 2009
    Washington
    553
    try arcticchat.com or arcticinsider.com... seems to be alot of that going around right now..
    2) 1977 Honda ATC90
    2)1985 Tecate
    2005 Banshee LE
    01 Honda 300EX
    74 Suzuki TC100
    66 Honda 305 Scrambler
    atcrider1's Avatar
    atcrider1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Montrose MI
    400
    your first mistake was getting a 600, biggest pos ac made, they are very problematic sleds. i would try to find a 800 motor, my brother and a friend of ours have 800s and they have no problems at all.
    on your sled, check both clutches, it might have a stiff primary spring causing high engagment, take it somewhere a get the carbs tuned it
    " I gotz the 8-track player mounted to my Oly, it's pretty sweet for trail side dance parties....."
    -Uller God
    Sep 2009
    Washington
    553
    Never had a problem with my 98 600 in the 10 years I've owned it.. *shrug*
    2) 1977 Honda ATC90
    2)1985 Tecate
    2005 Banshee LE
    01 Honda 300EX
    74 Suzuki TC100
    Dec 2002
    Orange County, NY
    1,772
    Have you ever torn down and cleaned the primary clutch? From what I'm reading it should be an annual maintenance item if you want to get the best performance out of the clutch.
    John
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
