Results 1 to 9 of 9
Thread: Yamaha OEM or Wiseco piston for Tri-Z ?
    Nov 2009
    texas
    19
    Just got a cylinder thats stock (std bore) and needs to be bored. Is the OEM Yamaha piston better than the Wiseco?
    Aug 2004
    Ab Canada
    4,368
    Depends on What your doing with it really.... a wiseco is lighter, stronger, and will last longer...In some case's.... but Requires a little more attention....Needs to be Set up right. If its a bone stock Z...a Stock Cast piston will work fine and wont give you any problems either.
    1985 Tri-Z-
    Jan 2008
    Cleveland Texas
    305
    What about those other piston kits sold on ebay? Around 50 - 60 bucks and includes everything.
    -Fathers 1985 200X
    jmax857's Avatar
    jmax857 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    bancroft canada
    354
    Quote Originally Posted by kasey200x View Post
    like a namura?
    Terryville,CT
    1,616
    Wiseco or oem you can get over bore oem pistons
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    I was told OEM are as good as it gets by my machinist friend. Something about the OEM pistons having a higher silicon content or something along those lines? There is nothing wrong with Wiseco though, they are great pistons for sure.
    Southern MN
    1,875
    Quote Originally Posted by tri-Z ripper View Post
    You can get overbore OEM pistons, the oem ones were made by sudco. I bought a .25 mm over for mine off ebay last year - paid about $65 shipped, and I am happy with it.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    I use wiesco.. I dont like oem anymore.. they tend to shatter when they go, usally takeing the cases out ,,
    Aug 2004
    Phoenix
    1,226
    It depends on the application. For most builds from stock to mildly modified a properly setup cast piston will last the longest because of the wear pattern/expansion rate of cast alum and the fact that you can set the piston/bore clearance much tighter that forged. Now on the other end if you are running an engine that has very high port timing or severe rod angle, high compression, nitrous, ect. then forged is the way to go as they are stronger for the job.
    4 Strokes are NOT the wave of the future!
