Thread: spark plug helicoil repair ?'s
    Southern MN
    1,875
    Hi, I have a nice original 1984 Yamaha Tri moto 200 that I am working on, and was looking for a little input on an idea I had. I got this 3 wheeler from the original owner. He used it for ice fishing, and thats it. About 15 years ago, the pullstart rope broke, and it had been sitting in a shed until I got it. I started working on it, and new right off the bat that the motor was stuck. I went to take the plug out, and it snaped off in the head! I really didnt put excessive force on it, it must have just been really rusted in there. I took the motor out, got the head off, and banged the piston free with a sledge . The bottom end looks really nice, and clean inside. At least it had oil in it, and the oil even looked fresh. The head had a lot of corosion and rust, so I blasted out the inside, and plan on having the valve seats re-cut, and new valves and seals installed, I have an in spec jug, and new piston and rings.
    Now for my question - I was wondering if I could drill out and tap the threads that are in there now - for a 12mm plug, to a 14mm plug (install helicoil for 14mm plug). The numbers on the plugs are slightly different - NGK 12mm plug (factory size) is somthing like D8EA and the 14mm I would be using would be a B8ES (you see a lot in 2 strokes). I think they would be the same heat range, and the thread reach is the same, so would I have any issues going this route? I have the helicoil kit for the 14mm - special tap for the helicoil OD and drill bit, seater tool, and everythig to do it correctly. Has anyone done this with good results? Thanks for any thoughts.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    I wish I could tell you I've done that before, but I haven't. I must say though, that is a very interesting question. I really can't see any reason why it wouldn't work.
    Silver Creek, NY
    86
    Heli coils are an acceptable repair for spark plug threads, but I can't help you with the heat range/reach comparision between the two plugs.
    2006 LTR 450-Dasa, PC3, Fuel Intake, much more...
    1991 Blaster-3 Mill Stroker, Flotek Ported, F7, Head Shaved, Flywheel lightened, VF3, 35mm PWK, much more...
    1984 200X-Work in progress
    1985 Tecate-also work in progress
    dksix's Avatar
    dksix is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2010
    North East Tennessee, USA
    610
    I think 14mm plugs are 1.25 thread pitch. You should be able to just drill and tap the hole, no heli-coil needed. My chart shows 14x1.25 threads should be drilled with a 12.8mm drill.
    Whats a 3 stroke??
    If it's in the heat range and the threads aren't longer there is no reason you can't.
    Many times thumper plugs come very close to the valves, but probably not that close...........
    Southern MN
    1,875
    [QUOTE=Dirtcrasher;932259]Whats a 3 stroke??
    Oops, that was a typo. My finger hit the 3 instead of 2. lol . I'll give this idea a try if I cant find a decent head soon, and let you guys know how it turns out. Thanks!
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
