Results 1 to 3 of 3
Thread: 1992 chevy s10 4x4 trans swap
    Jul 2004
    minnesota
    689
    i have a 91 chevy s10 4x4, its got the 4.3 v-6 and 700r4 trans. the trans is junk. i'm wondering if i can use a turbo 350 trans from a 2 wheel drive and remove the tail housing and bolt the transfercase to the th350, its just a theory of mine, let me know what i need to do here. i'd like to run the th350 if possible. thanks dallas
    my trikes:
    1983 honda atc 200x-k&n filter
    2002 yamaha raptor 660r, yoshimura slip on, prm grab bars
    1978 chevy nova, 454 v8, bds blower, 150hp shot of nitrous, full roll cage, a real power house.
    1991 chevy s10 4x4 350v8.
    1986 250sx
    YES its fast NO you cant ride it.
    newfane ny
    1,277
    the 350 will bolt right up to the 4.3 but not sure about the t-case, then is there any sensors in the 700 that send signals to the ecm for the engine? not sure on that eather
    Michigan UP
    1,005
    You would have to buy an adapter to go from the th350 to the transfer case, the output shaft is different in your two trannys, I believe advanced adapters has the stuff that you will need. Also the length of the trannys is different so the adapter will make up for it, otherwise you would have to make driveshafts.
