Results 1 to 15 of 20
Thread: Why does my trike pull to one side during wheelies?
    Toronto Canada
    697
    I thought my "pulling to one side" problem was caused by mis-matched PSI in my rear tires - but after getting the pressure in both tires to be as equal as possible, my 250R _still_ pulls to the left whenever I wheelie.
    Here's a video showing how significant the pulling is:
    What else could cause such a pronounced pulling to one side? Any help greatly appreciated!!
    Feb 2009
    michigan
    2,387
    splines or hub stripped out on one side?measure the circumference of both rear tires
    1985 ATC 250R
    . Team Red Trike
    It's gotta be the circumference of the rear tires. One has to be a little bit bigger than the other. Try swapping them around and I bet it will pull to the right.
    Aug 2009
    Chesterfield, Virginia
    845
    Tires or could also be bad swing arm bearings (chain would torque the weight to the left) a bent frame,or something else that would cause an exaggerated shift of weight
    TRIKE INTERESTS
    A1/A2 TECATE's
    BIKE INTERESTS
    ATK, Husqvarna, Maico, Harley Davidson & Yamaha Twins
    PLEASE KEEP AN EYE OUT FOR THE FOLLOWING STOLEN 3/30/2012
    1999 ATK 260LQ ENG# 425681 Red/White/Blue VIN# 4MAV1CC43XA009376 (Its the last one missing out of four the first three were destroyed)
    My Feedback
    Toronto Canada
    697
    Quote Originally Posted by HuffieVA View Post
    Thanks for the ideas guys, I'll look into each of your suggestions.
    I immediately thought - hey, this could be it (swingarm bearings) since I know mine are in need of replacing, but on the 81-84 250R's the chain is on the right-hand side, so if there is slop/play in the swingarm bearing, I would think the trike would pull to the right in this case... but maybe I'm over-thinking things...
    ontario
    1,131
    could be axle or bearing??? check and see it everthing lines up, pull the tires and hubs make sure your frount wheel is straight and measure from the frount axle to the back and if it is out you may have bent somthing just enought to make it go to the left. hope this helps
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    Aug 2009
    845
    Quote Originally Posted by Xhumeka View Post
    Opp's, but in my defense, I'm not really a Honda guy...
    TRIKE INTERESTS
    A1/A2 TECATE's
    BIKE INTERESTS
    My Feedback
    ontario
    1,131
    hole on your 250r is a right side drive??? so if the bearing are gone it would pull to the right not the left wright
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    Toronto Canada
    697
    That's alright - you _are_ a Husky guy though (as am I) so that makes up for the fact you don't ride Honda
    Baltimore, MD
    6,088
    Have you checked in the mirror to make sure your buttocks are of equal size and weight? Unequal buttock distribution could be a problem! LOL Bearings, chain tension, rear axle out of alignment could all be possibilites. Balance can also be a factor as well.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Oct 2009
    FF, Man.
    774
    I dont know man those wheelies look damn fine to me really tho, I would think it would pull to the sprocket side if anything. Must be worn pivot end?
    My 3WW Feedback Thread:
    Salut Gilles
    Crest California
    3,014
    Shift your weight?
    LED obsessed
    2015 Yamaha FJ-09
    Xfile's Avatar
    Xfile is offline Just Too Addicted Arm chair racerJust too addicted
    Apr 2007
    Shiocton, Wisconsin
    700
    I bought a new set of maxxix razor MX's for the back of my 200X.....with equal air pressure in them they not the same size, it pulls hard to the right during wheelies. Kind of disappointing for a $115 pair of tires. I have Kenda claw MX 18's on my 86X and they have no problems at all.
    Don't worry...just run watcha brung...
    bobotech is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    spokane, wa
    363
    I have no idea but that video was awesome. God almighty, I wish I had a place like that to ride. Looks like so much fun in that field. Great video.
    Masshole
    2,191
    Quote Originally Posted by Xfile View Post
    I got a pair of holeshots with this problem. Equal pressure it will walk crooked.
    I tried swapping them left to right and it will affect the opposite side.
    Long story short one needs 2 pounds more rhan the other.
    Just compensate with air and run it.
