I'm cleaning up internals and replacing seals! :-D What's is Honda's Part # (I think it would be in the factory service manual) for the tool to reach down in and hold back up on the internal part that can spin when you try to take out the allen screw, or tighten it up? Can someone post a picture of this tool and what the end looks like? What methods have some of you guys used for holding backup on it when you didn't have this tool? I've dissasembled one of my good forks completely. I got lucky, the screw came out. The other fork wont. Plus i've got two other bent forks I'd like to tear down for parts. Any help is greatly appreciated!!
Also a fork spring question. I see on the bike bandit schematics that there are pictures of the main springs for the fork. One of the springs is in two pieces, one is not. I have the springs that are in two pieces. Is this part of the difference between 85 & 86? Also, were these two piece fork springs designed to make lowering forks easier? In other words, you just reposition the smaller spring and washer underneath the top out spring to lower you forks?? This has got to be what the design is for. What a great idea Honda had there.
One other thing. Please give me some fork oil recommendations and the oil level from top of tube. What is the factory weight? Should I go with heavier oil? Any info would be great!
Thanks!
