Results 1 to 10 of 10
Thread: What size socket do i need?
    Dec 2009
    BFE
    1,202
    Im working on a 85 250sx and i need to put new brakes on it. What size is the nut that holds the hubs/brake drum on? Its bigger than any socket i have so i am going to town to get a socket what size is it? Thanks
    "I'm Kind Of Like The Turtle Man Of 3Wheelers."
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    Beaver Falls, PA
    2,666
    I believe it's 19mm.
    Dec 2009
    BFE
    1,202
    no its bigger i tryed a 22mm the biggest i have and it was too small
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    Apr 2002
    s.w. michigan
    6,498
    I just went out and checked my 85 250es (bigred) and it is 27mm if that may help.
    Dec 2009
    BFE
    1,202
    ive done some research and Ronnies.com parts microfiche the 85 250sx has a 20mm nut and the 86 has a 18mm nut. I found a 24mm socket and its too small. Do i have some kind of rare 1 off machine the nut on mine looks original. any ideas guys?
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    Dec 2009
    BFE
    1,202
    27mm sounds about right anyone else know if thats whats on a sx?
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    Woodsrider's Avatar
    Woodsrider is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2009
    Eastern Passage, NS
    238
    Yeah...the size of nuts and bolts is determined by the diameter and pitch of the threaded part...not the size of the wrench/socket that fits it...so the 20mm listed for your axle nut is the diameter of the threaded shaft...not the size of the socket required to remove/install it. A 27mm socket works on my '85 SX ...and my ES is the same.
    ct
    1,396
    Ditto on the 27 mm
    Beaver Falls, PA
    2,666
    Ooops, I misunderstood... I was talking about lug nuts!
    Dec 2009
    BFE
    1,202
    I took my bike to a friends house that had some bigger sockets. the nut that holds the hubs on is a 27mm thanks for all the help!
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
