I was wondering if anyone has used ART Piston kits. I found a site that is selling them for $60 for 83-85 200x. Since funds are low and i cant afford Wiseco I figured id give ART a shot If I can be sure that the quality is pretty good. Thanks
1985 200X
66mm H&S Piston
Little Bit Bigger Cam
Bassani Exhaust
1985 350X With Bassani Exhaust
1983 Honda 200E (PARTING OUT!!!!)
1985 Yamaha Tri-Zinger
My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
Not sure but I think oem honda piston are ART piston....pretty sure I have ever seen ART molded in a honda piston
1986 ATC500X
1985 ATC250SX
1985 ATC200X
1985 ATC250R
1986 ATC250R
1984 ATC250R
1981 ATC70
1984 ATC70
1985 ATC70
Custom built ATC70 / 250R laydwon swap
1986 ATC250SX FATCAT
i used to get shindy pistons for liek 30 bucks a few years back
ATC500X is correct. ART pistons were Honda's oem piston supplier back in the 80's. Whether or not they still are, I don't know.
Thanks guys heres the link http://www.hyperparts.com/wc.dll?ctw...1~1002~H831211
1985 200X
66mm H&S Piston
Bassani Exhaust
1985 200X
66mm H&S Piston
Bassani Exhaust
Top quality oem supplier of cast pistons back in the 80's. Many Yamaha and Honda 2strokes used art pistons as oem pieces. "Maybe others" I still have old worn out Art's from 250'rs, Tri-z and yz's collecting dust for some reason in one of my garage cabinets......I believe pro-x was chosen as an oem supplier in later years for many of the oem pistons, and fiber clutch plates too.
1985 200X
66mm H&S Piston
Bassani Exhaust
What size piston are you looking for ?
1985 200X
66mm H&S Piston
Bassani Exhaust
Went threw my stash and I have a NOS Big Al's 66mm 10.5:1 piston with rings . I dont have the wrist pin or clips but if you have a stock pin and clips it will work . 30.00 + shipping .
1985 200X
66mm H&S Piston
Bassani Exhaust
1985 200X
66mm H&S Piston
Bassani Exhaust
