Thread: How to restore forks to OEM finish?
    Jun 2006
    Illinois
    491
    Does anybody have any techniques, tips or advice on how to restore a set of 85' 250R lower fork legs back to the OEM finish? I don't really want to polish them. Or do you know of someone that can do it? Any help is appreciated, Thanks.
    danteross77's Avatar
    danteross77 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2005
    Texas
    339
    I seen a guy restoring an old honda ct polish them a bit just to clean them up and the brush them with a fine wire brush to restore them back to oem, maybe you can find someone to donate some old forks to practice on. He did it all on a bench polisher.
    Jun 2006
    Illinois
    491
    Maybe a brass brush will work. I'll give it a shot. Thanks for the reply.
    They look great polished, but they aren't polished from the factory.......
    You can find threads on how to polish them, it involves increasing the #grit on the sandpaper and then buffed.
    Depending on how much you ride, where you live, how long your keeping it; You make your decision but it's a bit of work to polish stuff up and there are lots of threads on it.
    GKING does a GREAT job polishing them for an extra reasonable cost! Check him out if your frustration level hits the roof
    Jun 2006
    Illinois
    491
    Thanks DC, If I can't get the factory satin finish I want then GKing is probably going to get them. I came across an article that involves different grades of steel wool also. We'll see.
