Thread: atc 125m clutch job
    Miami,Fla.(305)
    808
    atc 125m clutch job
    hi,- i'm changing the clutch discs on a 85'125m due to clutch slipping (low transfer of power). ive done many 185/200/250r but not 110/125.- (this is nothing close to it). i got new vesrah springs that are labeled for this bike, but look like the ones for the 185/200? i dont see where they go.-i'm so confused... any pointers/tips on this reassembly looks complicated. i dont want to screw up. -i got all the damn phillips bolts off cover!-(chisel & 4lb. mini sledge) to all bolts.- i've got the haynes manual but would like more info, i dont understand this set up. is the centrifical and manual clutch all in one? what are the springs you have to change look like? i dont see them on the manual.
    Monroe MI
    5,786
    Miami,Fla.(305)
    808
    thats better -thank you mm. but i'm still not sure about the springs- is it those tiny/thin ones that apply all the pressure?. the springs sold to me are big?
    Miami,Fla.(305)
    808
    o.k. the pressure plate springs were hidden in the rotor. (after removing the 4 bolts on the rotor with- chisel & ).- strangely ,they dont appear on the diagram in the haynes manual.
