Greetings All !!!
I am a new memeber and naturally I have a problem I could sure use some help /suggestions with. I have an 84 honda 200es. it was flooding out the spark plug about every 10 minutes so I bought a carb kit and installed it. I also checked and adjusted the vavles. I was told that to adjust the valves intake open adjust exhaust .002 and then reverse it for the intake. I did that. so here is the problem ...
bike starts up and idles fine... when I give it gas it acts almost as if it is spark knocking.... wont rev up to higher rpms smoothly (yes I am reving it slowly). I set the screw at 1 5/8 turn which I understand is supposed to be a good starting point.
ANY help/suggestions would be GREATLY appreciated!!!!!!!
Thank you !!
Randy
