Results 1 to 8 of 8
Thread: Removing drive shaft from 250sx transmission
    Sep 2006
    Evansburg, Alberta
    34
    So i want to get into the transmission to fix a problem I have with third gear, anyways I have been following the manual to a t, I have everything off, both side covers, cylinder, piston, starter.... and I'm ready to take the engine out of the frame to split the cases, except the manual makes no mention on how to separate the driveshaft from the transmission to do this. I dont want to just start unbolting stuff without knowing what I'm doing so any help would be appreciated. Thanks
    1985 250SX- Cobra Pipe, Uni Air Filter, PRM Grab Bar, Maier Plastic---Cat Walk King
    2000 KX 250- Pro Circuit Pipe And Silencer, Tag Bars, Boyseen Power Reeds, Twin Air, UFO Plastic
    19?? TE Commuter 390- Waiting to be worked on.
    Apr 2002
    s.w. michigan
    6,498
    Yeah, the sx and es drive shafts are really hard to dislodge when pulling the motor IMO.
    Although the manual says to take the motor out the right side of the machine, I prefere the left side.
    That allows me to lift up + forward and tip the motor out AND the whole time working the front of the drive shaft back off the spindle on motor with a screw driver.
    Yep, don't take the motor area apart to get to the angle gear. Well, you know what, you are going to split the cases anyway so it might not matter ???
    i have heard of folks removing the rear end so the drive shaft will drop out too ,,,
    They are not easy no matter how it is done. Tight fit, heavy motor ,,,
    john
    Dec 2007
    Quebec,Canada
    1,013
    The drive shaft is easy to remove......the SX drive shaft is extensible,mounted with a spring,use a screw drive and push on it,it's the spring that keep the shaft on the spline.
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    newfane ny
    1,277
    as 500x said take the screwdriver and push back on the collar where the u-joint is the shaft will collapse and slide off the final drive. and if you need any tranny or final drive parts i have all of it from a 250 shaft drive engine that had 50 hours on it.
    Sep 2006
    Evansburg, Alberta
    34
    And can i access this collar and u-joint by just taking off the boot?
    Apr 2002
    s.w. michigan
    6,498
    Sliding it back, yes.
    Sep 2006
    Evansburg, Alberta
    34
    Thanks alot guys, that was quick
    newfane ny
    1,277
    yes you have to push the boot towards the swingarm then use a screwdriver and push the top of the driveshaft down towards the swingarm, it may take a couple of trys it can be a pain or it will go easy one of those deals. i have a ton of shaft drive stuff if you need anything
