One of the biggest suggestions people make to help make them handle better is to raise the back end of the bike around an inch or so. Also some people talk about tire sizes. If you use a single shock, you will have to reinforce the frame some. There are some swingarms you can change out with minimum mods and you can run mag wheels and have a rear disc brake as well. Plus if you don't mind modded over stock, you have alot better choice of better front brake calipers too. It's pretty wild to see what all people are doing with the bikes after all these years. Best of luck with your new bike.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
