Results 1 to 15 of 18
Thread: Honda Oil
    Okanogan Co., WA
    48
    Honda Oil
    I can't find the type of oil recommended by the manuals for my 85 Big Red. The guy at Napa said that type of oil wasn't made anymore, that they had changed the classification letters/numbers. He recommended regular 5w30 engine oil. I didn't buy it, I bought Delo 30w that said Specially Formulated For 4Stroke Engines, gas or diesel. Now my kickstart won't work/slips. Wondering if the heavy oil or the type is causing the slip. The Delo's classification is CF/SL. The manual says use Honda 4stroke, SE/SF. What do you guys use??
    Monroe MI
    5,786
    1,736
    Honda's GN-4 is great! or yamaha's yamalube
    any 4 stroke motorcycle oil will do the job, just make sure its motorcycle oil/atv oil
    texas
    567
    so could the fact im using 10w-40 cause mine to smoke? as the oil is a lighter weight when cold? should i switch to straight 30?
    1,736
    Quote Originally Posted by twitch101 View Post
    nope, thats not the cause of your problem. if smoking when its cold (in cold weather) is normal, just as long as it stops when it warms up. if not then you probably need new piston rings or valve guide seals. if it smokes when its warm outside, even with a cold engine smoke is bad. your burning oil either way. oil weight wont effect this, at least as far as i know
    Feb 2009
    Wisconsin
    521
    Quote Originally Posted by Mr_RPM View Post
    I agree 100%
    1985 Auto X lots of upgrades
    1982 Honda 185s 3inch wheel spacers, bassani exhaust
    2001 400ex
    1983 110
    We need more threads on oil in here.
    Maine
    73
    i use any 10-30 synthetic oil for vehicles out there....was told by a relieable source that thats as good or better than any thing ever run in those or recomended
    TRIKES....BADDD ASSS BIKES!!
    1986 200x
    1995 300ex
    2000 400ex
    1989 CR80
    1996 CR 250R
    1997 XR 70
    1977 YAMAHA XS500
    1989 KITTY CAT
    muddog's Avatar
    muddog is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2009
    Manitoba
    225
    i run 10-40 all year round bit of a pain to get going in winter but for a piece of mind i think its worth it
    Using a manual isn't that like cheatin?
    There ain't quite nothing like the smell of diesel fuel in the morning!
    1,736
    ill run anything from 10-30 to 20-50. normally 10-40. i like the thick stuff on hot days where im gonna be riding real hard and get that engine HOT. in cold weather 0/10-30 and for stop go stop go situations. and 10-40 is a good happy medium for a good average riding
    Okanogan Co., WA
    48
    I just recently learned that the newest oil API classification replaces the last one, so going by that, any oil made from about 87 on should work. Running 5-30 now, prob. gonna try the thicker stuff for the heat this summer. Thanx 4 the suggestions guys! If I find that website, I'll post the link. Here you go, you be the judge. Tell me what you guys think. http://www.calsci.com/motorcycleinfo/API.html
    Jul 2006
    western ny
    3,366
    i found honda oil at my local honda place .. its pricey but worth it.. ive found it lasts longer and doesnt harm the clutch pack or anything like that. i use to use Valvoline 10w 30 and that seemed ok as well..
    GIT IT RAAAGGGGG !!!!
    Manheim, PA
    5,816
    shell rotella
    Nov 2009
    1,147
    Thanks for that chart. That is great. Something to know if you can find SL,or SJ, it has a higher zinc content than the newer SM, often the bargain oil is previous years spec oil. However emission standards have required them to put less zinc in new oil. So sometime the bargain oil is actually going to be better than the more expensive stuff.
    Auto oil will not ruin your clutch in any 3 wheeler. Honda designed them to use regular auto oil, so it is fine to run it. It is in everyone's service manual. Just change your oil frequently. ATV/motorcycle oil does have additives for the clutch, so the clutch might last longer, but auto oil is just fine.
    Manheim, PA
    5,816
    i ran auto oil for 30,000 miles in my one sportbike with a wet clutch, ya know what it did.......NOT A DARN THING! and the clutch never needed adjusted or anything. i changed it every 4K which for 6 years!!!!!!
    that old saying is 100% bullsheet in my book cuz i proved it wrong and had no probs...so what did i do, got another bike and ran it in that for another 10K, same thing, nothing and i road wheelies all time time for miles.
