Results 1 to 7 of 7
Thread: Heli-coil or Time-sert
    Nov 2008
    Coon Rapids, MN
    956
    I have a couple striped out cylinder head studs and was wondering which one would be better to repair this? Thanks,Alex
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    Baltimore, MD
    6,088
    Do you need cases? I might have some.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Nov 2008
    Coon Rapids, MN
    956
    Thanks, Pat but I have other cases but this is my only good DT175 cylinder so I need to fix the head studs on it.
    My feedback.
    My album
    COLORADO
    685
    I would run a heli-coil. I have fixed High Compression Harley motors with the coils in the bases, and had no trouble at all. Just use red or green Loctite. Green only comes off with extreme heat, but lasts and does its job better than red.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    Dec 2002
    Orange County, NY
    1,772
    I would also think that a heli-coil is sufficient. I had a head bolt hole strip on on a big block Chevy (apparently its not uncommon) and my friend at the machine shop fixed the hole with a heli-coil. I never had a problem with it.
    John
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
    Aug 2005
    Lockport, NY
    2,395
    Personally I'd use a time-sert. But I have all the kits. They are very expensive. But they work alot better than heli-coil. Its a full bodied insert.
    Nov 2008
    Coon Rapids, MN
    956
    Thanks guys for all your input. Thanks, Alex
    My feedback.
    My album
